Bad idle speed only cold start (W210 E50 AMG)
00 C200 & 00 C55 & 06 SLK55
If you have bad MAF, will forcing "bad performance/little bit playing in low ideal/bad fuel consumption"..!
try to diagnose the car first, MAF is soo sensitive for "RPM ideal range/proper mixture/stable performance",,
that will directly affect to the fuel trim & functional signal of O2 sensors..!!
ZAYED,,
ZAYED,,
2020 E 300 Coupe and 2019 GLS 400
Unstable idle could be the result of:
1- Dirty/bad MAF.
2- Vacuum leak.
3- Old spark plugs/wires.
4- Clogged/bad EGR system (the valve could be stuck partly open while idle)
5- Bad O2 sensors.
6- Partly clogged catalytic convertors, since it's only noticeable on idle and exhaust pressure is low.
7- Valve covers leaking into the plugs.
8- A problem in the fuel system (pump, filter, injectors....)
9- Carbon build-up causes the valves not to close properly.
I can't help you precisely, but these engines are a PITB when it comes to diagnosing rough idle/misfire.
I'm diagnosing the same issue, drove me crazy.
1- Dirty/bad MAF.
2- Vacuum leak.
5- Bad O2 sensors.
w210 E50 AMG
Cyl. 1 and 2 also is smooth running
but the picture has not come out,(left all cylinders)at a sharp turn to the right car stopped for a second as if out of fuel ( only a right turn )?
If fuel trim is OK, prefer to check MAF & TB..!,
if you replace any of them, and those issues still remain, afraid your ECU went away, which i hope NOT..!!
ZAYED,,
ZAYED,,
Try to check if there are any leak around the MAF, or "8" O-rings in intake manifold,
also position sensor in the TB may NOT reads the air pressure properly, this also could cause same your issue,
i know this is some kind of Hard job on M119,,
little bit patient will solve this mystery..?!?
ZAYED,,
ZAYED,,
w210 E50 AMG
Тhis is a problem that occurs when a cold start today and warmed car.When the car is cold I can't touch the accelerator , dies out , bounce ..
