Flickering headlight
My left headlight used to flicker occasionally and went out completely recently.
What's the best way to diagnose this? I hope it's not an electrical issue that involves the replacement of the complete headlight assembly and more of a simple bulb issue.
Assuming it is a bulb issue, what model and brand of bulb should I purchase for it and is the replacement easy enough to do a DIY job?
Finally, it seems the foglights aren't stock. Here are some photos to give you an idea of the setup.
In short:
1) The low beam is yellowish-white
2) The head light is white
3) The foglights are bluish-white
Error:
Low-beams:
Foglights
Light cluster showing the different shades:
All lights switched on:
Is this what the stock setup looks like (had to use a member's photo):
In short:
Error:
Low-beams:
Foglights
And can I buy these to fix the headlight problem?
Amazon.com: SYLVANIA H7 SilverStar Ultra High Performance Halogen Headlight Bulb, (Pack of 2): Automotive
Are your headlights xenons? If so you might need a D2R bulb, first I would try switching the bulbs from the other light and see if it still does not work. It could be the bulb or the ballast that is having issues.
Ozimandius (05-28-2016)
Finally, the Data Card for my E55, which shows that it did come with Xenon as stock:
600 HEADLAMPS - CLEANING EQUIPMENT
617 _______ - 19951002 - LAMP UNIT: XENON HEADLAMPS ASSYMMETRICAL
617 210____ - 19960726 - XENON HEADLAMPS, LEFT-HAND TRAFFIC
Other
Lamps: HELLA
Other
Lamps: HELLA
I also found this:
http://www.europerformance.co.uk/pag...category=bulbs
Thanks a lot, that really helps. I'll get the ballast checked first, and if it's not the problem, I'll get these bulbs, in pairs.
Good news! The bulb from the other headlight worked, so it was a bulb problem, and I ended up buying a pair from Amazon.
These are the ones I bought and they worked beautifully:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The bulb that died was an Osram, while the other side was a Philips D2R too, so it's been stored as a spare bulb now.
