valve cover gaskets... anyone know the torque specs?
doesnt seem that daunting of a job just need the valve cover bolt torque specs if anyone has them id appreciate it. anyone else replace their gaskets? anything i should be aware of?
2020 E 300 Coupe and 2019 GLS 400
- Watch out for leaking fuel when you disconnect the fuel line. After releasing the pressure from the maintenance valve, the amount that leaked was almost 200ml.
- Clean the area very well, you don't want anything to fall in.
Good luck
Good luck
"Watch out for leaking fuel when you disconnect the fuel line. After releasing the pressure from the maintenance valve, the amount that leaked was almost 200ml."
Where is the maintenance valve? I need to replace my DS valve cover and that fuel hose is definitely going to be an issue.
Thanks!
Thanks!
