Old 06-12-2015, 06:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
How do Reset Service Reminder ?
Old 07-10-2007, 08:45 PM
06E55AMG's Avatar
Can someone tell me how to reset the Service Reminder ? Thanks
Old 07-10-2007, 10:36 PM
SLR199's Avatar
door closed, key position 2. Scroll down in the menus until you get to "A service exceded by 23 days" or something to that nature. Hold he reset button down unti you get "confrim service interval by pressing the reset button". Hold it down for 3 seconds and it should reset.
Old 07-11-2007, 12:59 PM
tucsonbroker's Avatar
'15 E63S P30
That did not work for me. Mine is currently counting down to service C, 22 days to go.
Old 07-11-2007, 01:18 PM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
MY07 info is located on the W211 forum in a sticky.
Old 07-11-2007, 06:55 PM
SLR199's Avatar
then youll probably need to do the service confirmed. I forgot that the new models added the additional services. Try this one. door closed key position 1 (make sure you have the temp. screen up before starting) immediatly after turning to posistion one, press the reset button 3 times. and the battery voltage should come up, page down to serivce data menu.use plus and minus to select service data and hit page down to select. then use plus and minus to scroll down to confirm overall service, then hit page down. It should say service confirmed. It will probably take a few mins or you next interval to come up but it will show. let me know how that works.
Old 07-12-2007, 12:14 AM
'15 E63S P30
Worked! Thank you!!!
Old 11-04-2008, 06:14 PM
tomdrum4035's Avatar
e320 Bluetec
newbee here
hi all, just found the site and reset the service reminder - used the key in the first position, hit reset 3 times.....etc... and it worked. driving a 08 e320 bluetec.
Old 11-05-2008, 01:24 AM
RHBENZ's Avatar
08 S550, 08 E63, other non-Green cars
I just had a complimentary service done, 1-3k miles(service A?). What excatly did they do? No details on the invoice and my service A warning still comes on.
Old 11-05-2008, 06:36 AM
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
Because that wasn't a Service A. Please read your manuals and search the forum.
Old 11-05-2008, 12:14 PM
RHBENZ's Avatar
I understand service A was not performed on my car. I guess I didn't form the question properly. I took my car in for first comp service. The service A warning was on. They "serviced" the car with some other issues I had asked them to check out. I got the car back not knowing they didn't reset the warning, though I didn't know at the time since the car was running when I got in. I noticed it a couple of days later when I drove it again.
So since they didn't actually changed anything, what can I look for to see if something was actually done other than a car wash? Again, this is a different dealership than the one I usually go to.
Old 11-12-2008, 02:50 PM
phatmitzu's Avatar
2005 E55
*READ HERE*
https://mbworld.org/forums/showpost....52&postcount=4
Old 11-12-2008, 08:12 PM
sack5000's Avatar
2015 AMG C63 S
Since they did a car wash, check to see if your car is scratched (good chance of it). I always just get the oil changed and leave it at that. The service intervals are purely a profit center for the stealer and a complete rip. If they take your wheels off to inspect the brakes, they will warp your rotors. Anyway you see how I feel. The thing is, there is nothing to check out but they will make you think there is. Good luck.
Old 05-31-2009, 06:17 PM
jpohl402's Avatar
E55 then E63, now back to an E55
Time to reset my service indicator on 63.....
Every time in the past I did it, hitting the reset button would clear my trip odometer as well.
I do not want to clear my trip odometer this time, is there a trick (i.e. hit reset quickly, hold reset, etc)
Thanks.....
Old 06-12-2009, 01:48 AM
d33pa's Avatar
05 E320 4Matic
my intention is not to hijack this thread, but since my query is of the same nature, I will post here.
I recently purchased an 05 e320 4m, C service is now due. I was curious to see what service, and additional items were needed, so I went to the menus mentioned ^^ and wrote all the codes down. I then scrolled to the confirm service menu and inadvertently confirmed, now it says next c service is 7xx days or 15000KM (Canadian Model). Since the service is booked next week, and I already reset this service, will the dealership know what to do? Will the FSS System pick up that it still needs the services and report again? Luckily I wrote down all the codes that were on the menu so I can tell them verbally (i guess).
Thanks in advance for your time and help.
Old 06-12-2009, 10:58 AM
cahiil55k's Avatar
211-55
d33pa, the dealer will know what to do. Just make sure you tell them you reset it so they don't end up giving you the wrong scheduled maintenance work.
Old 06-13-2009, 01:35 AM
jangy's Avatar
2015 S212
Same menu as dyno mode. Just flip through once its up.
Old 11-02-2010, 10:30 PM
tbal's Avatar
Haters crazy
I tried all the listed ways to reset the service reminder and none work. Any help? 06 e55
Old 11-03-2010, 10:01 PM
zonnies619's Avatar
2006 E55 AMG
I have an 06 E55 and just reset mine last week.
I kinda just followed the steps below which i found on another thread on this forum from an instructors POV :
1. Insert the key and turn to position 2.
2. Using the button on the multi-function steering wheel, scroll to the ambient
temperature screen. Now use the button to scroll to the next service due
display screen (wrench symbol).
3. What is the next service due for this vehicle? ___________________________
4. Press and hold the “reset” button for 5 seconds until the display changes.
5. What is the title of the display that now appears? ________________________
6. Use the button on the multi-function steering wheel to scroll down and
highlight the “ITEMS” option. Select this option using the button.
7. What services are listed?
NOTE: You may have to scroll down to view additional items if a down arrow
appears in the lower left portion of the display.
____________________________ __________________________
NOTE: These service items are listed in the W211 service sheet.
8. Press the button to return to the “SERVICE MENU”.
9. Use the button to scroll down and highlight the “CONFIRMATION” option.
219 Mod 9-1 FSS PLUS Introduction (WFF) 08-16-02
3
10. What are the 3 options under the “CONFIRMATION” menu?
A. __________________________________________________ ________
B. __________________________________________________ ________
C. __________________________________________________ ________
11. Make sure the “CONFIRM” option is highlighted and press the button.
12. What is now displayed on the screen?
__________________________________________________ ______________
NOTE: The “Standard oil” option is for the US market. This is the selection you
should select when servicing the vehicle.
13. Make sure the “Standard oil” option is highlighted and press the button.
14. What is now displayed on the screen?
NOTE: This display indicates that all of the service items have been completed.
15. Press the button to return to the service menu.
16. Highlight and select “CONFIRMATION” using the button.
17. Using the button, scroll down and highlight “CANCEL SING. ITEMS”.
Select it using the button.
18. What is the last service item that appears in the display? __________________
19. Using the button, scroll down and highlight the service item indicated
above and select it using the button.
20. What is displayed in the instrument cluster? ____________________________
NOTE: You have just cancelled a single item from the list. You can cancel
more than one item using the procedure you just performed.
4
21. Press the button to return to the “CONFIRMATION” menu.
22. Using the button, scroll up and highlight the “CANCEL CONFIRM” option
23. What is displayed in the instrument cluster? __________________________
NOTE: You’ve just cancelled ALL of the service items that you confirmed
earlier.
24. Press the button repeatedly to exit FSS PLUS.
25. Turn the key off and remove it from the ignition.
If you have noticed any parts that need to be replaced on this vehicle, please inform
your instructor now.
Instructor check point ______________
Old 11-30-2010, 08:47 AM
cambrally's Avatar
2009 E 63 AMG & 2010 E350 coupe
i've tried this but on step 2 pressing briefly the reset (ODO)
i've tried this but on step 2 pressing briefly the reset (ODO) button does not display the battery voltage and i'm stuck....any other ideas?? i've changed the oil myself and only have about 5500 mils on there....appreciate any feedback
Old 02-20-2011, 06:02 PM
03'55AMG's Avatar
AMG
Press it three times rapidly while at ambient temp screen
Old 02-21-2011, 08:44 AM
cambrally's Avatar
i was able to get this done - you need the odo then reset...thanks everyone
Quick Reply: How do Reset Service Reminder ?
