Check Engine Light is on!
Old 09-26-2007, 10:25 AM
AMG Rider's Avatar
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
Two weeks ago, i was cruising late at night, and CEL came on outta nowhere.
My car was still running the same way that night (w/ CEL on), but the next day, it felt like my car had lost about 300hp+++ and my CEL started to blink like crazy~
i took it to my guy and he scanned it for me..he told me its misfiring from right side somewhere. But, we cant figure out what the cause is! its driving me nuts!
Its been at that shop for more than a week now..
So, my question is what could be the cause of this CEL?
btw, my guess is
1. spark plugs
2. O2 sensors
3. Secondary cat (damaged? from bottoming out somewhere?)
4. Kleemann Header (Hope its okai! i just replaced it last year..it cracked)
one of these~~~
any help would be appreciated~
Old 09-26-2007, 10:30 AM
V12Godspeed's Avatar
Your worst nightmare...
Man that sucks, I can't believe your headers craked also...Hmm not good. Well it could be many things but until they don't discover it we can't tell. Hope she is ok and makes it on time for MIR.
Old 09-26-2007, 10:31 AM
rflow306's Avatar
2005 E 55
btw, my guess is
1. spark plugs
2. O2 sensors
one of these~~~
Which cylinders does it say are misfiring ?
Check coil pack and wires for that cylinder.
AMG Rider's Avatar
thanks man~btw, my header cracked last year...had that replaced...hopefully its not cracked again~
Old 09-26-2007, 10:36 AM
AMG Rider's Avatar
i believe he checked it two days ago~think the coil pack is okai~
about misfiring, i remember him saying 1-4....im not really sure but ill find it out..
Old 09-26-2007, 10:53 AM
snags's Avatar
2005 E55 AMG Alabaster/Charcoal/Pano
Talking
injectors,coil pack, crank sensor, its crazy how many miles??who is the mechanic?? hopefully not the same guy that left ur wheel nuts loose!!!!
Old 09-26-2007, 12:15 PM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
The easiest thing to do is have your MB dealer do the scan. They will be able to isolate it right away, and then you can figure out what to do.
Old 09-26-2007, 05:55 PM
Sunny55's Avatar
2005 SL55 AMG
Dude, that sucks. I hope you figure things out either with your guy or your dealer. What shop are you taking it to? Broadway? I think going to the dealer may be faster.
I've heard of the kleemann headers cracking, hope mine doesn't! Knock on wood.
Good luck with everything and let us know what happens!
Old 09-26-2007, 06:47 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Joon,
Please pm me the codes you retrieved from the ME.
Adam
Old 09-26-2007, 08:01 PM
AMG Rider's Avatar
MB dealer uses Star Diag.. right?
my guy is using the same comp..
we'll see how it goes...supposed to get my car back tomorrow~
Old 09-26-2007, 08:02 PM
AMG Rider's Avatar
No, i took it to my guy in long island.
he has all the tools(i think...)
so, we'll see..
how's ur project goin?
Old 09-26-2007, 08:03 PM
AMG Rider's Avatar
Originally Posted by AdamG@EuroElites
Joon,
Adam
Adam..I just called him, but he didnt answer.
ill find it out soon and pm it to u...
Thanks for helping me out~always!!
Old 09-27-2007, 07:47 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
Good luck Joon, hope its a minor issue so you can get it resolved asap and have your beast back.
Old 09-27-2007, 08:48 AM
pcalver's Avatar
2007 SL550 - Aegean Blue; 2008 E63 Wagon - Iridium Silver
I'm sorry, but that's like saying that the local optometrist at the mall uses the same tools as the board-certified retina specialist, so their diagnostic abilities are the same. Based on lots of professional experience, I can assure you that diagnostic ability lies between the ears of the user of the tools, not in the tool itself.
Old 09-29-2007, 10:37 PM
Ted Baldwin's Avatar
300ce
btw, my guess is
1. spark plugs
2. O2 sensors
one of these~~~
.......mmmmmm. I have become somewhat of an unwilling expert with check engine lights in the last 2 months. Here is my info.
.......The codes are usually P0300's such as P0301, P0302 etc. the 1 and 2 identify cylinder one and two respectively. This does not tell you anything other than that the cylinders are misfiring. Look for additional codes such as p0400's, P0100's. If there are no such active codes, look at the pending codes. The P100's are for those cars with MAF's. The P0400's are EGR codes causing exhaust gas recirculation.
.......The causes of such misfiring are devided into two broad categories. One category is problem with fuel and the other category is problem with electrical and EGR problems. There is the category of emissions control systems, these usually will not cause your engine to misfire.
.........The simplest fuel problem is a bad gas cap. I highly recommend you check this first. Don't make the mistake I made by checking this last. You can get a clue that you may have a bad gas cap if your CEL comes on after re-fueling or when your fuel tank is half or less. Physically inspecting the gas cap does not help. If your state has mandatory emission testing, the emission shop can check your gas cap fucntionality for you, or you may simply replace it. Yes, a bad gas cap can cause your cylinders to misfire. It did mine. Apparently, it makes your O2 sensors go nuts.
........Other fueling problems include, a bad fuel pump, bad injectors, bad fuel pressure regulator. I have learned that the problem is seldom the fuel pump. If you have a bad fuel pump, your car is unlikely to drive at all. Yes, I changed my fuel pump. It was not the problem, at least in my case.
.........You can have a flow test of your injectors done. I have no expoerience with fuel pressure regulators. Thank god, it is one thing that did not get replaced, yet.
.........Electrical problems that can cause misfirings are bad spark plugs and bad coil packs and ignition wires and bad spark plug wires,. In a new car such as yours, it is not the coil packs and ignition wires. Further, if you habe multiple cylinders misfiring, then it makes it even less likely to be coil packs and ignition wires wires because you would have to have multiple ones go bad at the same time. Check your spark plugs and the fit of your spark plug wires.
.........EGR can go bad. The code is a P0400 code. If your EGR needs to be replaced, make sure they clean out the EGR tubes and vacuum lines. CAUTION: A bad gas cap can cause a P0400 code. Yes, I replaced my EGR and cleaned the EGR tubes. Yes, I had a P0400 DTC, but it was not my EGR. It was my gas cap.
.......Other candidates include oxygen sensors, and damaged CATS. If you have a bad oxygen sensor, you should have a an oxygen sensor code. The code number escapes me at this time. If your CATS are bad, you generally can hear them rattling as you drive. Turn of your stereo and open your windows and listen.
..........Overall, if you have multiple cylinders misfiring, it is generally a simple problem. If you have a specific cylinder misfire. it can be more serious. In wjhich case you should do a compression test of that cylinder.
..........I am sure someone else can add more info. Good luck.
Ted
Old 09-30-2007, 12:09 PM
AMG Rider's Avatar
Ted
Thank you Ted!!!the best write-up so far~lol the shop did a compression test. and the result was pretty bad...
Cylinder 1-165
2-160
3-95
4-175
5-175
6-150
7-175
8-175
they took the spark plugs out and there was oil all over it..(ill post some pics later) So, they switched the spark plugs and told me to take it easy since it could be internal damage.(Cylinder 3 for sure i think..)
and they told me they got rid of the check engine light. So, i picked my car up on Friday and test drove it first. The exhaust when i started up it smelled even worst(pure gas..told them to check my exhaust..but i dont think they did..) and the exhaust sounded alot louder than before. (maybe my secondary cat is damaged?? i dont have Primary cat due to K2)
Check engine light wasnt on then..after driving it for 3-4 minutes, it came right back on and at some point, it was blinking crazy!! and i felt no power at that point...so i decided to leave my car there and extend the warranty...the guy told me they need to take the head out to see whats going on inside..
At this point, im very very frustrasted and i dont know what to do....(plus i dont like leaving my car anywhere other than my house for too long...its been almost 2-3 weeks)
anywayz thanks again for helping me out and if u have any thoughts, please help...i think im gonna fix my car 100% and sell it~im so sick and tired of all this crap...
Old 09-30-2007, 12:17 PM
Jrocket's Avatar
E55
Thats not good.Im gonna say broken piston/piston ring landing.
Old 09-30-2007, 12:24 PM
rflow306's Avatar
2005 E 55
Cylinder 1-165
2-160
3-95
4-175
5-175
6-150
7-175
8-175
Did they perform a leak down test on that cylinder ?
One way of testing if its a ring issue is to add a little oil in the cylinder and re doing a compression test, if the compression goes up you have a stuck or damaged ring. If the compression barely changes it's most likely the cylinder head.
Old 09-30-2007, 12:31 PM
AMG Rider's Avatar
im not really sure if they performed it for not....probably not since they didnt give me a perfect answer....i pmed the guy who is fixing my car...im really frustrated with this whole situation...i dont even know what to do....i just extended my warranty for now..
Old 09-30-2007, 12:49 PM
sack5000's Avatar
2015 AMG C63 S
Hang in there and keep it, once it's fixed you will have it behind you and the warranty is sweet to have. It would be hard to sell it and try to explain the work....
Old 09-30-2007, 03:34 PM
300ce
...........I know how you feel. I have the same problem in two of my cars. One car has even had the engine replaced due to broken rings. The problem with CEL and the misfiring is still there. The essential problem is NOT the replacement of the damaged ring or piston........that is easy and requires no great intellect. The real question is why did the ring or piston got damaged? Notice that you have a misfiring from the entire right side. The individual cylinder with the low compression or broken rings is just a symptom of the problem. The same thing can happen to the other cylinders on the right side.
Having replaced an engine due to this problem, I can tell you that the reason you get broken pistons is due to bad a/f in the cylinders. They need to find out why? Look at your long and short term fuel trim adaptation values. DO NOT be shy. It is your car. DO not take the car back unless there is an answer to why the car ran lean. You need a mechanic who is very curious, not one who just wants to get you back on the road.
Ted
Old 09-30-2007, 09:21 PM
MOROSO55's Avatar
2006 WHITE RENNTECH E55
Joon, long time no see. Good luck wit all that sht.
i hate leaving any of my cars anywhere for more than a minute. but i will all work out. unfortunatly we got to be patient
Old 10-01-2007, 10:36 PM
Jrocket's Avatar
E55
Hate to bring this back up,but any info on your car yet?
Old 10-01-2007, 10:44 PM
Former Vendor of MBWorld
ChicagoX's Avatar
W211 E55
.......... The real question is why did the ring or piston got damaged? Notice that you have a misfiring from the entire right side. The individual cylinder with the low compression or broken rings is just a symptom of the problem. The same thing can happen to the other cylinders on the right side.
Ted
Great advice.
Good luck, J.
Old 10-01-2007, 11:01 PM
Vadim @ FD's Avatar
S600TT, R350
#3 - detonation - done.
Sorry, to be negative................
Quick Reply: Check Engine Light is on!
