View Poll Results: DIY/How-to sticky on the top?
Yes please.
13
100.00%
No thank you.
0
0%
Voters: 13. You may not vote on this poll
DIY Thread- Read Inside!! Great Info!!
2005 E55
I for one enjoy working on the car myself. Many of the DIY/How-do threads on this forum have been extremely helpful. I was wondering if we can have a sticky which collects all the DIY threads for member's reference. Such as the DIY header install, DIY TB install, sneaky ECU reset, service reminder reset, washer mod, etc...
Your thoughts?
DIY Pulley Install by: BrianS
https://mbworld.org/forums/w211-amg/209778-diy-pulley-install.html
DIY 80mm TB Install by: BrianS
https://mbworld.org/forums/w211-amg/204657-re-80mm-tb-mod.html
DIY Headers Install by: BrianS
https://mbworld.org/forums/w211-amg/208213-diy-header-install.html
DIY Steering Wheel Paddle Shifters by: BrianS
https://mbworld.org/forums/w211-amg/238652-mp-steering-wheel-installed.html
DIY LSD Install by: BrianS
https://mbworld.org/forums/w211-amg/225767-diy-quaife-install.html
DIY Fuel Pump Leak Fix by: BrianS
https://mbworld.org/forums/w211-amg/219571-diy-gas-smell-fix.html
DIY S/C Clutch Install by: BrianS
https://mbworld.org/forums/w211-amg/207506-diy-s-c-clutch-install.html
DIY Brake Change by: BrianS
https://mbworld.org/forums/w211-amg/199010-diy-rear-brake-change.html
DIY I/C Pump by: Vadim @ VRP
https://mbworld.org/forums/showthrea...78#post2376178
DIY I/C Pump by: BrianS
https://mbworld.org/forums/w211-amg/216325-diy-ic-pump-e55.html
DIY Split I/C Circuit by: BrianS
https://mbworld.org/forums/w211-amg/213966-diy-heat-exchanger-prep.html
DIY V1 Hardwire by: xraymd
https://mbworld.org/forums/e-class-w211/104516-v1-install.html
ECU Reset How-to by: Jakpro1
https://mbworld.org/forums/w211-amg/148019-holy-crap-you-guys-sneaky-ecu-reset-works.html
Service Reminder Reset How-to by: SLR199
https://mbworld.org/forums/w211-amg/201245-how-do-reset-service-reminder.html
Washer Mod (Lowering) How-to by: Rafal
https://mbworld.org/forums/w211-amg/107267-lower-your-e55-20mm-0-8-80-cents.html
Serpentine Belt DIY by: Clive
https://mbworld.org/forums/w211-amg/251323-serpentine-belt-diy.html#post2922396
Bi Xenon retrofit by: Yacht Master
https://mbworld.org/forums/w211-amg/231016-bi-xenon-retrofit-50-pics-56k-no.html
Renntech ELM DIY install by: kompressed55
https://mbworld.org/forums/w211-amg/257269-renntech-lowering-module-install-w-remote-diy-ers.html
VRP HEM DIY install by: blueknight
https://mbworld.org/forums/w211-amg/256575-dhl-just-arrived.html
Supercharger Belt Replacement by: kompressed55
https://mbworld.org/forums/w211-amg/239591-supercharger-belt-replacement.html
Evosport Header Install by: kompressed55
https://mbworld.org/forums/w211-amg/219966-evosport-header-install.html
Your thoughts?
1 Post
2004 E55 AMG; 1995 Porsche 993 Cab.
Good idea...
Rennlist has something along those lines, but rather than a sticky, it's a seperate subforum... Easier to get to all the stuff in one place I find.
How about it mods?
How about it mods?
Administrator
Thanx for all the work. Its stickied and closed at the same time. For further DIY additions please contact the responsible W211AMG forum mod to have it added.
I just added two more DIY's to the end
https://mbworld.org/forums/showthread.php?t=257269
https://mbworld.org/forums/showthread.php?t=256575
Thanks to phatmitzu for the heads up.
Added some more
https://mbworld.org/forums/showthread.php?t=239591
Added another
https://mbworld.org/forums/showthread.php?t=219966
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Added another:
Okay, here is the step by step for ya
In Star have the tech go to Main Groups then click Control Unit Groups the click Drive, then click ME SFI Motor Electronics, then Control Unit Adaptations, then Correction Programming, then Electric Suction For Engine or Air Cond.
The screen will look like below.
***Very important. You want to INCREASE the value up to it's max by clicking F5 until screen says "reached it's maximum". This will allow the fan to come on sooner. If you decrease the value on the screen, the fan will come on later in temp.
All done.
All done.
Administrator
Here are member kompressed55's DIY Brembo installs in three stages:
Click Here for Stage I
Click Here for Stage II
Click Here for Stage III
Thanks for the submission kompressed55...
Administrator
Another excellent DIY post- from our esteemed and well educated member Marcus Frost:
https://mbworld.org/forums/3307806-post1.html
Administrator
More excellent DIY's all courtesy of Komp55:
Here's a DIY install link of a MP Design steering wheel:
DIY MP Design steering wheel install
And this is the 4th and final installment of the Brembo BBK install:
DIY Brembo GT Big Brake Installation, Part 4
Administrator
A very nice compiliation of all stickies from MAN55LE:
https://mbworld.org/forums/w211-amg/...-addition.html
