Trunk will not close
2005 E55
Remote trunk close feature will not work when I press the red button in the trunk. It opens find with remote & will close when the button is pushed inside the car. The red button is illuminated though, nothing happens when I press the button. No beeping or clicking.
I know it worked last week when I tried it. I haven't done anything to it since.
Wondering where I should start to look for the problem
2005 E55
2008 E63, White/Black, P030
Hi. I also had a similar problem with my E63 2008 w 14,000 miles. When I pressed the trunks closed button, it closed like about 1/4 way then opens again. It did this several times at once and I was not able to replicate this problem again. I was wondering if the remote is far away, because my keys were about 15ft away.
Former Vendor of MBWorld
W211 E55
If you press the close button instead, it should close but not lock.
I would like to revive this thread. I was opening my trunk to put suite case in and it wouldn't shut. So I closed it manually. Then when I got in car it makes an SOS call. It has done it 4 times now. I believe it is because the trunk latch is sticking. How do you clean and lube the latch. It's on a 2008 e350 4matic. Weird that a stuck trunk latch is causing the car to call an sos!
Hey all,
My trunk works fine. But sometimes it takes two pushes to close it. It will make that distinctive sound when first pushed but won't close. Clicking the second time closes it and there is no sound. I am worried something is not engaging properly and wondering what can be done now before it breaks.
