Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Mercedes-Benz C-Class AMG: How to Replace Crank Shaft Position Sensor
Step by step instructions for do-it-yourself repairs
Crank Shaft Position Sensor DIY with PICS
#76
The Mercedes Benz dealer found the problem with the engine amber light shown on the dashboard. They replaced the sensor and now everything is back to normal again. Before this is was hard to start the engine which took about 3-5 times. Thank you....
#77
By the way I paid about $ 341 for it here in Bangkok, Thailand. I am sure if I purchase it on the outside auto parts it would be much cheaper. Well.. they have to check and diagnostic the system anyway...
#80
PLATINUM SPONSOR
Should have PM me, I have a few laying around. It is rare, but when they go, you get left dead on the spot.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#81
I just did mine last Friday.
Symptoms:
Hard start when hot (even if just hot sitting in sun) - Car would turn over for 5-6 seconds before firing
On some starts, Idle would be very low 400 - 500 RPM for a few seconds before coming up to normal.
Based on all the treads, I did the CPS- All problems resolved. I am glad I did not wait for it to die.
Symptoms:
#82
2004 E55 AMG
Symptoms:
Symptoms:
#83
Thanks a million...
Took her to a local repair shop and mechanic said he couldn't do it due to starter immobilizer kicking in if CPS removed.
Since I've had part and tools ready I've decided to do it myself before work; 45 mins, $400 saved!
Car runs noticeably smoother, rough shifting is GONE.
Thanks again for the pics.
#84
2004 E55 AMG
Thanks a MILLION Shardul!!! I just finished replacing mine and it did not take long at all. I started the car a couple of times and the check engine light turned off. As long as you have the proper tools and instructions this car is easy to work on. I drove the car for awhile to heat the motor and tested it again. The car turned over quickly and before I changed the part it would take a few cranks. Now I am back on the love side of this love hate relationship with my AMG.
#85
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
#86
2006 E55 AMG
ok so i got the symptoms , replaced it with a napa part and all worked for a day or two . today i am driving and give it about 75% throttle from the 1-2 shift and car cuts out , almost like it a trans problem and i can replicate it by doing a 1-2 shift in any trans mode . the car shuts off and will restart first try and have a cel on with a po335 code , no trans codes . any clues?
#87
2003 E500, 2004 S430 w/BT-Puck/Tail
2 CPS's in 10 days
Just thought I would chime in and report another...or rather another 2 successful CPS transplants. If you can believe it I got stuck in the garage (2003 E500) got the part from O'Reilly's and an E8 socket and went to work. Real tight with lots of blind touch and feel in there, used the twist-tie trick for putting back the screw and all was well. Yeeeehaa!
10 Days later Murphy decided to drop by and curse my wifes 2004 S430. She called me that her car would not turn over...I told here to wait and try again to make it home...Bought another CPS. This one although visible and with more approach sapace was a little trighter around the actual sensor. There was some kind of metal plate around the perimeter of the sensor which made it hard to maneuver around...but that plate saved me once from loosing the screw once or twice. This time I had to use and antenna magnet to get that screw out (while the sensor was stil in there). you see I try to loosen the screw first just over a 1/4 inch and then pull up the sensor then loosen the screw all the way then pull out the sensor with the screw still in the sensor but for some reason I almost lost it. Soooo.....when putting the CPS back in this time I could not use the Twist -tie trick because the metal plate would not give me enought room to pull the Twist-tie out afterwards. Sooo, to make a long story short I held the CPS with the screw in it with the socket extention but no rachet handel and hand tightened it. The rest is history....Phew!!!
#88
2006 cls500, 2006 E320 4matic, 1998 chevrolet suburban, a pair of addidas top tens
Whoa! This is one dangerous fail. My wifes just went (05 320 4matic) on the highway of all places with tha little ones in the car. I'd like to thank anyone who did a diy for this fix. I did it in about 1/2 hr. big hands and all did not have and e8 used a 6 1/2 ratchet bit fit perfect. part was from autozone 55$. saved major $doe on this from reading some posts $400 that is pathetic. Next up Valve Cover Gaskets on the CLS 500
#89
Obsidian Black C43, Silver C43, Silver Carlsson E-class wagon, Brabus G-class
How many miles were in your car when the CPS went out? I experienced this close to 100K miles. It happened in Central Valley California where summer temps are always over 100F. So it could definitely be temperature dependent.
#90
Ok problem #2 from the CPS and this time it is the Plug/connector that is the culprit. I changed the sensor as stated in earlier post and everything was well. The next morning the wife went to start the car and it did nothing but turn. So i thought maybe i over torqued the bolt so i did it over it started and i was like ok good. Then for some reason while the engine was running i went to make sure the sensor was stable and not moving touched the wire to the plug and it went off so now i think there is a short in the plug wires and the sensor was never bad. Does anyone know this part number for the CPS plug, can it be done DIY or is this a dealer issue? Please help. It is the plug he has in his hand
#91
03 E500 and Corvette
FWIW the hall effect sensor used in the CPS is a typical and most vehicles use them. The ones on my diesel truck with triggered fuel injectors use a hall effect sensor. I don't think the MB sensor is any better or worse than anyone else. The location (rear of engine) and heat (radiated off the rear of the engine by the firewall) will affect the life of the semiconductors in the sensor. So It probably isn't a problem with sensor design as much as location. IF it were on the front of the engine it would still see heat from the radiator, sides of engine mainfold. So Heat is the enemy of the solid state device. And yes they can partially fail. They are designed to put out a square wave timing pulse that is used to time the plug firing. But in a partial failure mode instead of a square wave they could put out a saw tooth wave which might give a weak start. This might allow the engine to run but have difficulty starting. I certainly am not defending MB on this one (after all the other failures I have had ) but it is probably just a heat related/age failure more so than a MB issue with design of the sensor.
#92
Thanks to Shardul and other contributors to this thread. I read this site regularly but rarely post. For a while my 2005 E55 has idled rough and started taking longer to start. I attributed this to Houston heat and the addition of several recent mods including 82mm TB.
Last night I finally threw a CEL after trouble starting and read P0335 "Crankshaft Sensor A Circuit Malfunction" w/OBD II. Searched this board and found these instructions. Not wanting to be down Labor Day Weekend, I picked up sensor at dealer this morning and an E8 at Autozone. Replaced the CPS this afternoon and car is running its best since I added TB and injectors a few months ago.
Thanks for posting tips for rookies like me. Saves alot of research time when things like tools needed, sensor location etc...are shared by senior owners.
One piece of advice, avoid dealer if you can. I was expecting $85 range but at Mercedes North Houston the cost of the CPS and a screw came to ~$210. Had I known this beforehand, I would have let car sit while I ordered it online.
#93
CPS failures are common on a lot of vehicles...I know on my F250 I drive regularly w/ the 7.3 Diesel I always keep one in the glove box. ford actually came out w/ a "new" CPS however it really didn't work any better. I agree w/ Vettedvr....the sensor location and the fact it needs a perfect signal every revolution of the motor to operate effectively....it's going to fail eventually. I would think a lot of other sensors in cars may not be working 100% either however their not as critical as a CPS sensor so their not noticed.
#94
CTSV/6sp Grocery Getter
Shardul and others , thanks for the tips and tricks on this DIY. It was a pain but better than paying the dealer or independent to complete the job.
Probably the only time I wished for smaller longer forearms and I am an average size guy
#95
2001 ML320; 2004 E55 AMG, 2013 C250, 2010 BMW 328i
Hard start but no error code
Glad I could help. I hate seeing people spend big $ having shops do simple jobs they can do themselves. A lot of this stuff is really not that hard with a lil guidance from people that have been doing it for a while.
Now let's just hope I can get my fat hand down there to undo the connector when my sensor shows up.
Thanks BBBSS and everyone for this posting. I replaced the CPS last year with BBBSS' help on the E55 then shortly after on the ML320. The E55 is still running good. However, the ML320 is starting to have hard start ... appears to be the same symptom but no error code ... yet. I took the CPS back to AutoZone and got a free replacement but the problem is still there. Could there be something else that causing it? Any comments would be greatly appreciated.
6/10/2014 - Updates: I finally fixed the hard start problem by replacing the fuel pump & filter.
#96
I'm still lost on how you get to it. You said the right side fender, but I'm not understanding the angle of the picture. Do you mean that side but through the engine compartment or from below or that I have to take the wheel off.
Just a little clueless and not much of a wrench
Probably stupid questions, given it is a CRANK shaft sensor, but....
#97
#99
Just had this happen to my car. Frikking 150$ from Partsource in Canada and I couldn't wait for online since my car is DD.
The pics in the first post are gone away.
Do I need to take off the Air filter cover ?
Do I need some sort of special screw to put it back in ?
Anyone has other photos ?
Any help would be appreciated.
#100
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
You reuse the bolt that was holding the old one in. The part number was given in case you drop/lose the bolt as it's a bit of a pain to get it back in without dropping it. Follow the lead of others with wrapping a tiny bit of tape or something around the bolt to help hold it in. Also don't just slam the sensor home with the bolt taped in place, this isn't that girl from Bangkok, get it part way in and try getting the bolt started carefully. Once you get the bolt started some you can seat the sensor fully and snug up the bolt. Snug, don't get crazy with it. Removing the airbox assembly (the box is held in by a couple tabs that push down into a rubber lined slot (Remember that girl from Bangkok??...) If you are having issues getting the airbox off you can unbolt the top and pull the filter out and try to pull the lower off separably, this usually goes a bit easier but is more work. You should be able to just pull the hose that leads to the front of the car off the front of the airbox carefully and wiggle the airbox while you pull it up to get the box loose without splitting it open.
If the airbox doesn't seem to want to come out don't get crazy, you don't want to break the tabs off or something like that. If it's really being a pain just pull the bolts out and take the top off the box, remove the filter and the bottom will come loose much more easily.
