Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-07-2012, 07:26 PM   #51
Drives: E55
Buy the whole kit, I think it comes with 10 long ones with T handles..
Yes it was T20, I'm pretty sure it's the same on the E55 and cls55
To remove this ad, register today or login if you already are registered!
Hulk is offline   Reply With Quote
Old 04-07-2012, 07:27 PM   #52
djrabbi's Avatar
Drives: 06 CLS55
djrabbi djrabbi2001 djrabbi
Send a message via AIM to djrabbi
Sweet. I think I am going to do it now since another 30min of light left...Thanks!
__________________
'06 CLS55
djrabbi is offline   Reply With Quote
Old 04-08-2012, 12:02 AM   #53
moosejaw's Avatar
Drives: none
Quote:
Remember its okay if the torx screw falls into the door.
today was the day for working on the benz
TTM Scoops
Black Grille
Door Handle
Someone should do a write up on the TTM scoops.
They are not clear cut as the others make them out to be.
moosejaw is offline   Reply With Quote
Old 04-08-2012, 12:26 AM   #54
Toadster's Avatar
Drives: 2005 E55 AMG
Todd Christ Toadster Todd Christ
Send a message via ICQ to Toadster Send a message via AIM to Toadster Send a message via MSN to Toadster Send a message via Yahoo to Toadster
TTM Scoops
Black Grille
Door Handle
the install is super stinkin easy...
1. line up the scoops as they would look 'installed'
2. mark a spot using a pencil, I used my a small drillbit to start a hole
3. remove the scoop
4. drill the hole using a small bit to break through the metal (I broke two small drillbits doing this) there are a few layers of metal in there, I then opened up the hole using a 3/4" bit and it worked fine
5. put the two rubber hose pieces on the tubing behind the scoops to keep them from rubbing/banging
6. assemble the scoop
a. bolt down the hole on top
b. then scoop
c. then rubber spacer
d. then the mount on the car (that you just drilled)
e. then the locknut underneath note: I put the locknut underneath just in case it would work loose - the locknut will just fall off instead of getting sucked into the INTAKE!
7. using the allen wrench on top and 1/2" box-end wrench underneath, tighten to finish
Click the image to open in full size.
Toadster is online now   Reply With Quote
Old 04-14-2012, 06:56 PM   #55
djrabbi's Avatar
Drives: 06 CLS55
Installed my handle but still doesn't work... Any ideas??
Old 04-14-2012, 07:20 PM   #56
Drives: E55
Did you make sure the connections are right, you can literally check if it unlocks by clicking the door handle even when it's hanging off, don't put it together until you verify that
Old 04-14-2012, 07:21 PM   #57
djrabbi's Avatar
Drives: 06 CLS55
There only one connection though, the push tab with 2 pins in it. When it was hanging off, it didn't unlock or anything either. I thought maybe it wouldn't. I guess I have to do something with star?
__________________
'06 CLS55
Old 04-14-2012, 07:36 PM   #58
Drives: E55
No need for star, did you buy the correct handle for your car that said W keyless?
Old 04-14-2012, 07:39 PM   #59
djrabbi's Avatar
Drives: 06 CLS55
yeah it has the black tab to unlock the car behind the handle too...I am guessing its an electric problem
__________________
'06 CLS55
Old 04-14-2012, 07:44 PM   #60
Drives: E55
Take off the back door one and try it on the front
Old 04-14-2012, 07:45 PM   #61
djrabbi's Avatar
Drives: 06 CLS55
okay i will try that tomorrow.
__________________
'06 CLS55
Old 04-14-2012, 10:26 PM   #62
Drives: W211 - E55 AMG
Is this a new or used handle? Mine was used, but worked right away (granted note very well, but that's because it's on it's last legs)
Celicasaur is offline   Reply With Quote
Old 04-15-2012, 12:06 AM   #63
Drives: CLS55 AMG
the door handles on the back doors of the CLS are different from the front ones... i had three of my door handles replaced under warranty... two still sort of work... anyways, when you plug the new handle in, it should work right away
pics for comparison
xpl0sive is offline   Reply With Quote
Old 04-15-2012, 07:24 AM   #64
djrabbi's Avatar
Drives: 06 CLS55
Yeah it is new from the dealer. When I took out the old handle, the connection had that green looking glue on it so i wiped it down and all. But still didn't work....Should I check through Star to see if there is a fault?
__________________
'06 CLS55
Old 04-15-2012, 09:53 AM   #65
Damn that must be a pain. I guess the next step would be to check the appropriate fuse for it, but I'm new to this AMG game, so it might have to be a star readout to pinpoint the issue.
Hopefully one of the other guys can advise better.
Old 04-15-2012, 10:21 AM   #66
djrabbi's Avatar
Drives: 06 CLS55
I don't think it would be a fust since all the other doors work
__________________
'06 CLS55
Old 04-15-2012, 03:00 PM   #67
djrabbi's Avatar
Drives: 06 CLS55
Figured out my problem. The pin from inside the door was broken so it wouldn't work. If anyone needs a silver door handle, let me know!
__________________
'06 CLS55
Old 04-15-2012, 05:10 PM   #68
Great stuff, at least it's working now
How much do these things go for at the dealer? I'd be interested but my car is black
Old 04-15-2012, 07:02 PM   #69
djrabbi's Avatar
Drives: 06 CLS55
they go for $300+...I can get it painted for like $30 and keep it at the regular price I bought it for.
__________________
'06 CLS55
Old 04-15-2012, 07:16 PM   #70
6spdcoupe's Avatar
Drives: '08 TBSS, '06 E55, '09 CX-7
http://www.linkedin.com/pub/don-amann/13/269/482
In the low-mid $100 range.
__________________
'06 E55, '08 TBSS, '09 CX-7
H900/BRAX MX4 x 2
Dyn Esotar 110s~430s~650~1200
6spdcoupe is offline   Reply With Quote
Old 04-15-2012, 07:17 PM   #71
6spdcoupe's Avatar
they go for $300+
I genuinely feel for the soul that pays near that.
__________________
H900/BRAX MX4 x 2
Old 04-16-2012, 12:55 AM   #72
Drives: CLS55 AMG
lol ya you buy these handles on parts.com for $150....
Old 05-02-2012, 04:37 PM   #73
berti_00's Avatar
Drives: AMG
Send a message via MSN to berti_00
bump this... my door handle is stuck i can't pull but everything works?? what could cause this?? do i have to remove door pannel to check why its stuck :/
__________________
ECU/TCU V4 Tune (EuroCharged )540whp 565wtq |S/C Pulley|OEM 82mm TB S/Grinded|Belt Wrap Kit|NGK colder Spark Plugs|Split cooling system|EvoSport Intake Spacers|C63 exhaust|X-pipe|Kleemann Headers|Primary-Seondary CAT-Resenator Delete|K&N filters|Heat Exchanger|Supercharger Pump|TTM Air Scoops|Custom 4" intake|19" Concaved Wheels|L.A.S.L Lowering Links|JL-M CF Front Lip|JL-M CF Diffuser|Carlsson CF spoiler |2013 LED Mirrors Arrow type|Euro Command|12% headlight tint |Philips Headlights|
berti_00 is offline   Reply With Quote
Old 05-03-2012, 09:27 PM   #74
berti_00's Avatar
Drives: AMG
i took mine apart and back in like less than 5 min... its easy and than i dropped the bolt lmao, took the door panels in less than 5 min bamm bamm and back on... it was good experience.. dont take it to dealer, its an easy job
__________________
Old 06-05-2012, 02:24 PM   #75
Drives: cls500
cls door handles
my driver door and passenger door handles acted up. they wouldn't unlock or lock. i took my car to the dealer, they charged me $315/ door hand, about $650 total to replace both handles. now its 2 days later and they both don't work again!!!! what do i do? the damn dealer charges $125 for diagnostics each time!
also, does anyone know of a good shop in the NY/NJ/PA area that can do retrofits of command units and other upgrades?
thanks
ovaid is offline   Reply With Quote
Tags
211, diy, door, doorhandel, e55, handle, interior, led, mercedes, removal, remove, replace, replacement, replacing, w211
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
