Pre-mod dyno ... a little low
Hi all
Here is a premod dyno I did yesterday. Only 368 HP. Couldn't get the torque reading. I removed the front cover and tried to hook the tach probe up to one of the plug leads but couldn't get a good tach signal. I was in a bit of a hurry so didn't mess with it too much. Does anyone know exactly where I can pull the tach signal? The place I took it to Dyno don't know much about Mercedes.
Dyno seems low. I have seen people putting 400s down. It probably didn't help blasting down the highway right before. Also I have noticed my S/C shuts down after several hard pulls on a hot day (at least that's what it feels like). I haven't checked IATs .. suspect my IC pump is not super healthy. That should change with the Meziere .. just thought I would share... Green line was 4th gear pull .. might ignore that one!
Thanks ... I tried that on the driver's side (number 2 I guess) but the tach signal was jumping all over the place ... line was not long enough to reach to passenger side. ... but should be the same right?
2005 E55 AMG
I am willing to bet money your pump is dead. The same thing happened to me. I put down 395whp with a rather squiggly graph like yours and then swapped to pump and put down 429whp with a super smooth graph.
368HP with the typical 19% driveline loss factored in comes out to 455HP....
400HP would be a 494HP motor. That would be pretty stout for a "stock" motor.
Probably a little bit of heat soak....and as I'm sure everyone will start telling you the number itself isn't very useful since every dyno is different.
-G
-G
I'm greedy ... I want more ... hence the power adders to come
Thanks ... yeah I think there may be an issue there. As I had mentioned sometimes the supercharger seems like it is just not there. Any way to check the pump itself or just look at IATs? I guess it doesn't matter, either way it's going in the trash
Several folks on here say 469HP quoted is a marketing tool and real numbers are closer to 500 anyway. Numbers other folks have put out seem to support the 500.
-G
-G
'05 SL65, '13 FX4 Eco
my guess is that you were heat soaked...
i was just at the dyno on sunday, a dynomite dyno, and i put down 411whp and 477wtrq and im sitting bone stock
2005 E55 AMG
Notice how squiggly your lines are vs. my latest dyno:
The lines are smooth and "smoothing" is at 0 vs. your dyno that has "smoothing" set to 5.
Thanks for taking the time to explain! I guess I really need to fix that heat issue (soon ... soon ). I think the ambient was only 90 that day.
