--car with arrow pointing up see workshop--??
Rating: Thread Rating: 7 votes, 5.00 average.
Old 04-03-2012, 10:09 PM
berti_00's Avatar
2016 Cls63s AMG
so the car is running perfect no issues or anything, however while driving today in some areas the road was a bit rough bumpy and shortly after i get the car with arrow pointing up workshop... car sits perfect on all 4 coners leveled so now am confused, i did quiet a bit off searching before making this thread, and alot of people got it and turned out to be the acelameter sensor or something like that... i opened the hood and each side has one right on top of struts, held by 2 screws and connector on top....
any advice would be great
if anyone in Tampa area has Star and would be willing to help me and run my system id really appreciate it alot..
Old 04-04-2012, 01:14 AM
berti_00's Avatar
2016 Cls63s AMG
200 views and nothing... damm this place is really dead :/
Old 04-04-2012, 01:20 AM
.trunzx's Avatar
2003 SL55, 1978 280SL, 2007 ML63
I get this message sometimes. You probably have a leak somewhere...
Here is what star says
Old 04-04-2012, 01:43 AM
justinwrock's Avatar
Ducati
My car does that from time to time on crappy roads while in sport 2.
Old 04-04-2012, 02:34 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
or it could be the pump is on its way out, id worry if it happens all the time. Occasionally is fairly common i think.
Old 04-04-2012, 10:44 AM
berti_00's Avatar
2016 Cls63s AMG
well it never happened before until i drove on that bumpy crappy road.... and 5 minutes later message pops up,
could it be the Acceleration Sensor
http://www.partsgeek.com/gbproducts/...nsor+2004+2005
Old 04-04-2012, 11:37 AM
spazmoid's Avatar
2018 E63s, 2004 E55 AMG
This just happened to me recently. I had no leaks but I would get the up arrow error message if I had a lot of weight in the car. It got progressively worse until the error would show up with just me in the car. I had the dealer run the code and they said the compressor was taking too long to come up to pressure. The car was sitting fine, not low, but it just took too long for it to level out. I bought a new compressor off ebay for around $300, replaced it myself, and the problem has been gone since. Dealer wanted around $700. Hope this helps
Old 04-04-2012, 11:40 AM
berti_00's Avatar
2016 Cls63s AMG
so you think its the compressor pump?
is this the part
http://www.ebay.com/itm/GENUINE-OEM-...ht_3228wt_1396
Old 04-04-2012, 11:59 AM
spazmoid's Avatar
is this the part
That's what I think it is, judging by my experience. I haven't hard any problem with that sensor so I couldn't tell you about that.
Old 04-04-2012, 12:36 PM
Alps's Avatar
berti, get the codes read first dude
Old 04-04-2012, 01:33 PM
berti_00's Avatar
2016 Cls63s AMG
okay i did get the codes, my buddy ran it on a computer and it came both left and right Accelerometer Sensor
Old 04-04-2012, 01:50 PM
vioilio's Avatar
2003 E55 AMG
Most likely all you have to do is to disconnect both Accelerometer Sensors and clean the connectors. This did it for me and no more troubles after that!
Old 04-04-2012, 02:35 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
mine did this off an on for about 6 months and then airmatic went out
Old 04-04-2012, 03:04 PM
berti_00's Avatar
2016 Cls63s AMG
your pump went out??^^^^
okay so am at work now and i parked the car and the rear has dropped while it seems the front has gone up...
what in the hell is going on???
Old 04-04-2012, 03:47 PM
novae500's Avatar
W211
I have ps arnott strut if you need one.
Old 04-04-2012, 04:34 PM
berti_00's Avatar
2016 Cls63s AMG
^^^ my bags are fine
it just looks like my car is having a pump going out code 5503 [recovery time during filling of central resivore is to long]
and the other two were the accelometer sensors front left and right.
Old 04-04-2012, 05:17 PM
izzyz28's Avatar
2004 E55 AMG
I have had to deal with this exact same thing three times. The first two times it was the plastic air lines that were leaking at the fittings, and the third time it was the airmatic pump itself that couldn't build enough pressure. I created a thread about it a couple years ago called "Mystery airmatic warning" if you want to search it.
Old 04-04-2012, 05:34 PM
gaspam's Avatar
no, my airmatic strut/bellow failed eventually and i had to get new one and it was the rear, which arnott doesnt make the cheap ones for so i had to get oem MB one... sucked big time
but from your codes, yours sounds like it could be a pump issue and will prob burnout if its constantly trying to fill up the resevior, but it also could be happening due to a leak somewhere else that is causing the pump resevior to continually deplete itself. if there is a leak somewhere within the airbag assembly then you will be in same boat i was... but if its just the compressor pump then you just have a little and much cheaper diy weekend project
Old 04-04-2012, 05:55 PM
berti_00's Avatar
2016 Cls63s AMG
yah bags are fine no leaks or anything detected... if It anyone has a pump DIY plz post it here so i could save a few bucks doing it my self...
thanks everyone for the help..
Old 04-04-2012, 07:23 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Had this same issue after I got rear-ended
Did exactly this and its been perfect since. the car rode like it was in sport II even when in comfort. To get to the rear sensor take the rear passenger wheel off then remove the fender liner. You'll see the sensor attached to the the body. Disconnect it and blow some compressed air over it. Plug it back in as securely as possible and call it a day. The sensors are located here:
--------> Click <--------
Old 04-04-2012, 08:31 PM
berti_00's Avatar
2016 Cls63s AMG
my rear one is good i only got the codes for front right and left
.. thanks for that link i now know were the rear one is..
Old 04-04-2012, 10:00 PM
MAXHO's Avatar
2003 E500
Start with pump. Check airmatick fuse and pump’s solenoid. When not enough pressure in the system or it’s not building up as fast as system needs it too – codes will be all over the place. If friend has STAR - run pump test.
Old 04-04-2012, 10:02 PM
berti_00's Avatar
2016 Cls63s AMG
we ran it and gave me this
" code 5503 [recovery time during filling of central resivore is to long] "
were is the airmatic fuse anyways..
Old 04-04-2012, 10:16 PM
MAXHO's Avatar
2003 E500
Open door all the way and you will se door on a side of the instrument panel. Have to use flat screwdriver to open it. Instructions/fuse location paper should be in there. But it's probably not a fuse - pump would come up at all if fuse bad. Check electrical connector on a pump. It may be corroded (especially if car from north) and pump from working properly. If you need pump check http://http://www.arnottindustries.com/part_MERCEDES-BENZ_Air_Suspension_Parts_yid18_pid127_gid511.htm
they have better price on e-bay, or if your mechanic orders.
Old 04-04-2012, 10:35 PM
berti_00's Avatar
2016 Cls63s AMG
i doubt its corroded it was a cali car its whole life and now in FL... that link you send me isnt working for me!!!
i am going after this so far as its the cheapest
http://www.ebay.com/itm/300652357153...ht_3228wt_1396
if you know of any place for a better price feel free to share it
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: --car with arrow pointing up see workshop--??
