Sign in using an external account
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: E55 K
#2 |
Drives: 2005 E55 AMG
You may have belt slip, although it could just be your mods. I get 14psi but I have a 178mm pulley and no cams.
#3 |
Drives: No longer stock '06 E55, A3 3.2 Quattro, LRD3 HSE
err you have a 3.06 rear diff??????
__________________
Rgds Steve 2006 E55 Iridium Silver [X] Modified |
#4 |
Drives: 2004 W211 E55K
How are you guys reading your boost im also curious if im losing boost?
__________________
#5 |
maybe I/C pump is failing and heatsoaking you to turn off the S/C ?
__________________
EC Tune | TCU Tune | FTP H/E | S/C Pulley | TTM Scoops | K&N| AZN 5K | Badge Spoiler Pedals 20% tint 446hp 487tq
![]() If you're new here, READ ME FIRST | DIY: Installing TTM Scoops on W211 E55 | 30-110 video NGK LFR7AIX |
#6 |
If the I/C pump is going i don't belive it would make any boost and would come and go with the power if im correct.
__________________
#7 |
Drives: 2006 CLS55 & 2002 SL55 (R129) Silver Arrow
I dont think your loosing boost. Your particular mods have made your engine more efficient (especially the headers and cams).
If you want more boost I'd go with a larger crank pulley.
__________________
![]() SL55 (R129) 5.7L AMG Kompressor engine, 85mm TB, SLR cam shafts, MAHLE forged pistons, ported heads, long tube headers, full AMG exhaust, AMG P030 Brakes, Quaife LSD CLS55 (R219) 85mm TB, RENNtech air box, Kleemann Headers, UPD Supercharger Pulley, Eurocharged ECU/TCU tune |
#8 | |
SPONSOR
Quote:
Just enjoy it!! ![]()
__________________
#9 |
Drives: 2006 E55 AMG
I make 14psi with a 195mm pulley, so I would be happy with your boost results with a 168mm.
__________________
CornFed E55 (e85)/Meth -10.84 @ 127mph-w/1.65 60ft-TUNED by TONY@BIP Slammed on VOSSEN CV7's http://www.youtube.com/watch?v=HHv4jhA2lyc http://www.youtube.com/watch?v=PZHxMP9BrOM http://www.youtube.com/watch?feature=youtube_gdata_player&v=96DNQbnYuBE |
#10 | ||||
Drives: E55 K
Quote:
Yes! It is rare! Quote:
Quote:
Quote:
Before mods I am running a 172 mm pulley with 15.2 psi (maximum) I am very unhappy. I don´t know if the new mods swipping the boost. 12.3 psi makes me dissatisfied! Only by running a 168 mm pulley I got 13.8 psi (without cams and headers). |
#11 |
Who cares how much boost you make man, as long as your HP has increased under the curve since your new round of mods, that is all that matters. You are probably making more power now with less boost, and that is exactly what you should strive for!
__________________
#12 |
Drives: CLS55 AMG
i think you are feeling no power after 180 mph is because of the 3.06 rear diff... if you had the regular 2.55 rear diff, you top speed would be better... 3.06 is better for acceleration
#13 |
Your boost is fine.
I agree with ^
__________________
#14 |
Drives: E55 K
I don´t talk about about top speed. Top speed is 202 mph with 3.06.
There is no power and by running 3.06 instead of 2.65 is more advantageous to climb fast to top speed. For about 4 weeks my car was running stronger with the same mods. |
#15 |
Drives: M3, E55, SL55
Your Boost level is accurate with your upgrades.
__________________
#16 | |
Quote:
What sort of RPM are you at at 180MPH? Are you doing any data logging to capture ignition timing, IATs, etc? I'm surprised that there are no fuel system mods in your list...... Long, top-gear pulls at WOT are pretty tough on the stock fuel system. I wonder if you are either running out of fuel or the injectors are at 100% duty cycle (static) at those kinds of speeds. -G
__________________
2006 - E55 Black (Sirius / Bi-Xenon / Premium Pkg with Pano / Trunk Closer / Keyless GO) ...... 41,145 original miles |
#17 |
Drives: slow
Can you please share information regarding your differential? (What its out of, if its an LSD, and how you made it play nice with the TCU)
__________________
![]() Ricer hoopty club member #2 Spending money I don't really have, on things I don't really need, to impress people I will never meet! On the way to creating the most ricer hooptie mobile... ever. |
#18 | |
Quote:
As for the fueling, he must be running SOMETHING other than stock. I have a lot less stuff than he does and my car was maxed out on the stock fueling.
__________________
Awaiting for the moment in my life where I can get back to modifying cars. Soon...hopefully. |
#19 | |||
Drives: E55 K
Quote:
At 180 mph exactly 6000 U/min At 192 mph exactly 6400 U/min Quote:
Quote:
#20 | |
Quote:
__________________
#21 |
Drives: 03SL55
Your not on a closed road, are you? Your gonna get your a$$ beat with a billy club
168 pulley making 12.3lb of boost, something wrong with your gauge homie. |
#22 | |
Quote:
You REALLY need to datalog and you REALLY need injectors.
__________________
#23 |
Drives: 2005 E55
I feel bad since im only seeing 12.0-12.8 lbs with a 178 pulley depending on how cold it is Ill see a tad over 13lbs sometimes also and you are crazzy to do 180mph like that.
#24 | |
Quote:
amazing thing these motors, with my v/6 i push 16 psi avg and 19 psi on a cold day. stack the pullies and you get 25 psi!!
#25 | ||||
Drives: E55 K
Quote:
the LSD is from wavetrac. How it made to plays nice with the TCU ask my mechanic at www.sportwagenwerk.bcd-ost.de and www.vortrieb-dresden.de Quote:
The oem boost is already 11.6 psi. By running a 172mm for month ago I had a peak of 15.2 psi on dyno. Quote:
Quote:
www.sportwagenwerk.bcd-ost.de Last edited by lorie; 04-14-2012 at 10:05 AM. |
| Tags |
| 2005, amg, boost, e55, iats, loosing, pulling, timing |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
