Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-17-2012, 08:29 PM   #1
Drives: 2003 E55 AMG
WOT hesitation after EC tune....Update
Back story:
2 weeks ago I had the Eurocharged 172mm pulley, Eurocharged tune, and CM30 pump installed in San Diego by ACG. Immediately noticed a hesitation at WOT. I initiall thought that it was a fuel pump so I had both replaced, problem remained though.
Fast forward to today:
I took the car down to Evosport and had them run the car on the dyno to see what was up and here is a picture of the dyno:
Click the image to open in full size.
The car goes absolutely pig rich at around 5k...sub 10.0. This would explain the hesitation as I'm probably misfiring at that rich of AFR. After reading a few posts online, is a bad CM30 pump possibly the culprit? I wasn't able to log IAT's, so is there a way to check manually for a properly functioning pump? I was told that the pump was hardwired when installed so I would be led to believe that when the key is in the on position I should be able to hear the pump running, which I don't. So either the pump went bad the day it was installed, it wasn't hardwired as I was told, or I have some other problem.
And my numbers were super crappy...sub 400tq and hp. I baselined higher than this stock!
To remove this ad, register today or login if you already are registered!
BenJ is offline   Reply With Quote
Old 04-17-2012, 08:49 PM   #2
CharlyE500's Avatar
Drives: E55 2006 / E55 2000 / White Odyssey
I don't think its IC pump failure..... when my stock pump failed you will feel your car like 200hp or less.......
__________________
Good judgment comes from experience, experience comes from bad judgment.
Kleemann ECU tune + Header + CM30 pump + K&N filter + E63 front conversion + SL55 Gun metal wheels
CharlyE500 is offline   Reply With Quote
Old 04-17-2012, 09:12 PM   #3
amg guy's Avatar
Drives: 2005 E55
looks like those numbers are uncorrected. pretty good for just a tune and 172.
The AFR is very rich. What did the stock AFR look like?
amg guy is offline   Reply With Quote
Old 04-17-2012, 09:20 PM   #4
berti_00's Avatar
Drives: AMG
Send a message via MSN to berti_00
unplug your battery over night plug it back in the morning and your good to go
__________________
ECU/TCU V4 Tune (EuroCharged )540whp 565wtq |S/C Pulley|OEM 82mm TB S/Grinded|Belt Wrap Kit|NGK colder Spark Plugs|Split cooling system|EvoSport Intake Spacers|C63 exhaust|X-pipe|Kleemann Headers|Primary-Seondary CAT-Resenator Delete|K&N filters|Heat Exchanger|Supercharger Pump|TTM Air Scoops|Custom 4" intake|19" Concaved Wheels|L.A.S.L Lowering Links|JL-M CF Front Lip|JL-M CF Diffuser|Carlsson CF spoiler |2013 LED Mirrors Arrow type|Euro Command|12% headlight tint |Philips Headlights|
berti_00 is offline   Reply With Quote
Old 04-17-2012, 10:06 PM   #5
skratch77's Avatar
Drives: 2005 E55
Are you serious?
for real 379ftlbs and 400whp with a pulley and tune? those are Horrible numbers and dynojets read high.
uncorrected means thats what the car put down with no corrections.
I would look at the intake temps and would think the car has a dead pump with that A/F
He is down 120rwt and 70whp btw with his setup
skratch77 is offline   Reply With Quote
Old 04-17-2012, 10:15 PM   #6
jmb614's Avatar
Drives: E55 AMG
Check your IAT's if you can. I am sure if you contact Jerry he will take care of it provided it is a tuning issue.
__________________
Custom tuned by Jeremy @
185 ASP Pulley//MBH Headers w/ Full 3" Stainless Exhaust//TTM Rail and Injectors//EuroCharged H/E with Trunk Tank//Zietronix ZT2 & Dashdaq w/ Wideband and EGT// Custom goodies coming soon.
jmb614 is offline   Reply With Quote
Old 04-17-2012, 10:27 PM   #7
Drives: E55
Quote:
Originally Posted by skratch77 View Post
Are you serious?
Ya Dynojet usually read higher
__________________
Eurocharged tune/ TTM scoops/ Sec. cats+ resonator delete/ Forgestar F14/ RennTech v1/ CF trunk spoiler/CF mirror cover/CF roof wrap/6000k HID headlights/ 35% tint/ E63 front bumper/ FTP Heat Exchanger/ CF Intake tubes/ Smaller S/C pulley
AKnight55 is offline   Reply With Quote
Old 04-17-2012, 10:47 PM   #8
kustom2k1's Avatar
Drives: 03SL55
This is a box tune from Eurocharged that you had put on the dyno afterwards? I doubt its the tune.
Usually high IATs are the culprit, you may have air trapped in your HE cooling system.
kustom2k1 is offline   Reply With Quote
Old 04-17-2012, 11:25 PM   #9
This is what I am kind of leaning towards at the moment.
Old 04-17-2012, 11:25 PM   #10
And yes, a box tune.
Old 04-18-2012, 12:26 AM   #11
Drives: 211-55
I think you should have just had EC reflash it to stock instead of throwing parts at the issue. A bad I/C pump would cause power loss across the board and not just hesitation at WOT. Your numbers are way low, even uncorrected because at 75*F and 34% humidity, the SAE correction factor would have been around 1.01 and uncorrected is 1.00.
__________________
PC Tune * 180mm * 82mm * K&N * JohnsonCM30 * PLM shorties * X-pipe * Secondary Cats Removed * Resonator Removed * Phen Spacers * -10 deg
cahiil55k is offline   Reply With Quote
Old 04-18-2012, 12:46 AM   #12
amg guy's Avatar
Drives: 2005 E55
Are you serious?
I would think 400 to 420 stock hp. 450 - 470 stock tq on a dynojet. So yeah it's down but I don't think a tune and 172 pulley will get you 470 plus rwhp, maybe 500 rwtq.
Most stuff I've done is on a Mustang which typically read much lower (actual numbers IMO)
What gear is the best for dyno pulls? 3rd or 4th? It looks like this was done in 3rd.
Old 04-18-2012, 01:40 AM   #13
backdoc7's Avatar
Drives: C300, Viper RT/10, E55
I've been thinking of getting the 172.. I'll gladly let you check your IAT's with my Torque app and bluetooth OBDII module if you'll hook me up for a ride once your car is tuned correctly so I can feel the difference of the 172 over stock..
I'm not too far from Irvine.. I'm in Chino Hills if interested.. I will say when my pump died, like Charley said above it felt like 200 hp less..
backdoc7 is offline   Reply With Quote
Old 04-18-2012, 10:14 AM   #14
skratch77's Avatar
Drives: 2005 E55
he is under 400whp with a pulley and tune and bone stock cars hit 420whp on dynojets,my car bone stock hit 390whp on a load dyno like the mustang you are used to and my car hit 461rwt bone stock on a dynojet.
he can easily make 460-470whp on a dynojet with a 172 and tune and 4th gear is 1:1 but most people use 3rd.It will give you less torque but hp is within 5whp from my own testing.
Old 04-18-2012, 10:15 PM   #15
Drives: 211-55
I just now read that your AFR was 10 . That's a poor tune even if its a box tune. Like I mentioned before, bring her back to stock just to see if things improve before retuning.
__________________
Old 04-19-2012, 01:06 AM   #16
Yeah, I'm going to reflash tomorrow and then if I have the time, look at the ic pump.
Old 04-19-2012, 08:40 AM   #17
skratch77's Avatar
Drives: 2005 E55
before you go retuning your car you should see if your intake temps are skyrocketing and causing the ecu to go rich.
your tune could be fine but its dumping fuel to save the engine.
any miss fire codes? and how ling have you been driving like this? you might want to swap out your plugs soon and Im sure your cats took a beating with the a/f also
Old 04-19-2012, 10:04 AM   #18
PREMIUM SPONSOR
Drives: 07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2013 GTR, 2014 CLA45 (Ordered)
Send a message via AIM to James@ACGAutomotive
Ben, if you would like come on down to us and we'll put your e55 on our mustang dyno and data log it. If a retune is required we'll work with Jerry to get that taken care of on our dyno.
Let me know, lunch is on me if you come down.
James@ACG
__________________
ACG Automotive
Your Southern California Preferred Installer for WEISTEC, Quaife, Speedriven, REVOZport and Kleemann
MBworld's Recommended Forgestar Dealer
Mustang AWD-500 Now on Site at the San Diego location
Now Operating from:
7884 Ronson Road
San Diego, CA 92111
877-422-4736/ 858-633-1017
extension 5
Providing same day Kleemann ECU tunes
New York Location Now Open
1516 Schenectady Ave
Brooklyn, NY 11203
James@ACGAutomotive is offline   Reply With Quote
Old 04-19-2012, 10:43 AM   #19
I might do new plugs but I will check them first to see their condition. I've driven the car a few hundred miles like this but I havnt gone wot but perhaps a few times and the afr's are fine at 1/2- to 3/4 throttle. The cats no doubt are hating life and you could smell them dying on the dyno but hopefully this can be resolved shortly to prevent catalytic failure. There have been no codes thrown either as well as no stored codes. I had the car hooked up to sds to be sure.
I'm in agreement with you that the issue can very well be the ic pump. I will just need to have it checked, perhaps tomorrow if possible.
Old 04-19-2012, 10:45 AM   #20
James@ACG
Alright, thanks James. I will keep in touch and I might be able to swing down tomorrow around 1030 if that works. Im thinking ic pump at the moment and I want to test it today to see.
Old 04-19-2012, 02:40 PM   #21
PREMIUM SPONSOR
Quote:
Let me know by email as i'll be in the back most of the day finishing a few projects.
James@acgsandiego.com
__________________
ACG Automotive
Now Operating from:
7884 Ronson Road
San Diego, CA 92111
extension 5
Brooklyn, NY 11203
Old 04-19-2012, 06:06 PM   #22
Little update. I took the car to my mechanic and they inspected the ic pump and it is indeed dead. They started off by listening to it with a stethoscope(sp?) and it wasn't running when the ignition was in the on position or when the car was running and hot. They then checked the current draw of the pump and it was drawing over 10amps so it was indeed dead.
Tags
73, 99, acceleration, apr, cm30, e55, evosport, hesitates, hesitation, iats, misses, open, pump, throttle, tune, wide
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
