Sign in using an external account
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Pressure Sensor Code after TB install
__________________
172mm Kleemann Pulley, ECU ,TB shaft grinded, 80mm TB, K&N, Secondary deleted, S55-Pipe, CLS AMG Exhaust, Johnson CM90, Split System, bigger HE |
#2 |
Drives: 2005 E55 AMG
Hmmm...never seen that code before. I wonder what pressure sensor they are referring to.
__________________
Awaiting for the moment in my life where I can get back to modifying cars. Soon...hopefully. |
#3 | |
Quote:
__________________
2005 Brabus K8 E55 Fully loaded, Running fast like hell, but cold as the north pole Tuned by: ![]()
#4 |
It isn't Map.
Map is Errorcode P0105. It should be to detect the boost or something like that.
__________________
#5 |
Sorry!
You are right it's the map sensor! P2007 B28 (Pressure sensor)(P0105) (P0105) = MAP Sensor Did somebody replace it already??? I hope i don't have to remove the sc again.
__________________
#6 |
Ahhh...P0105. I've gotten that more than once for no apparent reason. I think it could be because I reach 14+psi and I can't remember if the sensor is a 2 bar sensor, which would explain it.
__________________
#7 |
I'm not sure but i think it's an 2,5bar sensor.
I'm confused because i never had this code before installing the 80mm tb.
__________________
#8 |
I can tell you this. I replaced twice and still the CEL comes and that only happens when I drive on the highway on almost constant speed around 135 - 160 km/hr.
I also never had this issue until I was using the 82mm TB which is off the car now coz I will sell the car soon
__________________
#9 | |
Drives: 06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Quote:
#10 | |
Quote:
Maybe i really have to do the tb reset too Ahmad do you know the reason for the cel? Can you explain me how to chance the map sensor? Did your idle go up and down also? Thank you
__________________
#11 | |
Quote:
![]() My ideal will go a little bit down but it will start to hesitate soemtimes whne CEL is on. I am thinking of somethings but it could be wrong: 1. Either you have pressure leak somewhere before the sensor. 2. Or it tries to read higher than it should be even by fractions. 3. Tune is not 100% ok since system is circuits with feedback, depending on pressure coming to ECU from the MAP. If you are welling to spend 25 USD (that's what I paid for new OEM one), try to find a sensor that reads a little bit higher just in case it is problem of high reading or new sensor to be in the safe side or at least to eliminate the those options. Even if you reset the TB and used scanner to clear the code, it will show up again when you have the same situation and condition. Good luck, let us know how it goes.
__________________
#12 |
Of course i'll tell you what i could find out.
I bought the sensor now but i can't find the DIY.
__________________
#13 |
1. Open the surge tank on the passenger side, you will see the sensor just after the outlet of the IC towards the Y pipe. Use long key to open it, you will need to have some patience to do that
![]() I hope that you bought some aftermarket sensor that can read slightly higher range.
__________________
#14 |
Okay thx!!!!
:-((( I bought the oem one
__________________
#15 |
Did you resolve your issue?
__________________
E55 Wagon 176mm Crank Pulley, 84mm UPD Clutch/Pulley, UPD Belt Wrap, 82mm TB, EC LTH, Kleeman Cams, Ported Heads, TTM 550 & Looped Rail, Needswings CAI, TTM Scoops, 3 inch Exhaust, X-Pipe, No Cats/Resonator, Eurocharged HE, Trunk mounted tank with spray bar and 2 pump system, Eurocharged ECU and TCU Tune - Tuned by Jerry! Renntech V3 DLM Next on my list Not sure yet! |
#16 |
Drives: 03SL55
Sav, Munich hurt the motor.
#17 |
Wow I just read it on the other site, gutted for you munich55
__________________
| Tags |
| 2005, 55, b28, c240, cls, code, e55, merceders, mercedes, p0105, p2007, p2007008, pressure, sensor, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
