Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-26-2012, 02:05 PM   #1
Drives: 2004 E55 AMG
E55 SC idler pulley
Greetings!
I've changed the idler pulley bearing for the SC belt and I'm not sure which way the C-clip faces. front or rear?
If I put the C-clip forward then there is about 2mm endplay between the
pulleys.
If I put the C-clip aft then the pulleys are tight against each other.
Not sure which way is the correct way.
Could someone tell which way the C-clip faces?
Thanks, Jim
To remove this ad, register today or login if you already are registered!
jim5870 is offline   Reply With Quote
Tags
2004, amg, bad, e55, idler, pulley, pully, replacement, sc, upgrade
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
