Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-26-2012, 02:48 PM   #1
berti_00's Avatar
Drives: AMG
Send a message via MSN to berti_00
--e55 amg dipstick oil?? what are you using--
just thought id ask and see if any of you actually have dipsticks on your engines... i heard the ml430 has the exact measurement as the 55!!!
To remove this ad, register today or login if you already are registered!
__________________
ECU/TCU V4 Tune (EuroCharged )540whp 565wtq |S/C Pulley|OEM 82mm TB S/Grinded|Belt Wrap Kit|NGK colder Spark Plugs|Split cooling system|EvoSport Intake Spacers|C63 exhaust|X-pipe|Kleemann Headers|Primary-Seondary CAT-Resenator Delete|K&N filters|Heat Exchanger|Supercharger Pump|TTM Air Scoops|Custom 4" intake|19" Concaved Wheels|L.A.S.L Lowering Links|JL-M CF Front Lip|JL-M CF Diffuser|Carlsson CF spoiler |2013 LED Mirrors Arrow type|Euro Command|12% headlight tint |Philips Headlights|
berti_00 is offline   Reply With Quote
Old 04-26-2012, 03:06 PM   #2
Drives: E55 amg
no dipsticks on our cars
AMG E Power is offline   Reply With Quote
Old 04-26-2012, 03:11 PM   #3
berti_00's Avatar
Drives: AMG
no dipsticks or tranny sticks lol
__________________
Old 04-26-2012, 03:15 PM   #4
Drives: E55 amg
lol i know!!!! sometimes i would like to check the oil myself rather than trusting a computer with sensors that go bad. steelership probably has one u can order for over $100 ! F that.
Old 04-26-2012, 04:11 PM   #5
tbal's Avatar
Drives: Haters crazy
I would like to know this too. Cant trust the computer reading...
__________________
PB 11.65@123.16mph 1.74 60'
tbal is offline   Reply With Quote
Old 04-26-2012, 04:44 PM   #6
Drives: ML550
Buy the factory tool dipstick if you want to check the level manually. Unfortunately, it's not designed to actually remain in the engine like a traditional dipstick, but it works really well when used. I'm pretty sure a search here would probably yield the MB part number for it since I know this has been discussed before.
komp55 is offline   Reply With Quote
Old 04-26-2012, 04:58 PM   #7
Drives: 2004 E55 AMG
MB#120589072100
I just bought one off of ebay and it works just fine.
ziggityzen is offline   Reply With Quote
Old 04-26-2012, 05:17 PM   #8
berti_00's Avatar
Drives: AMG
hold your horses guys i think i have found our solution... just went to the dealer and ordered a ml430 dipstick and they are the same exact fitment and it was 21 dollars
part number is 113.010.04.72
__________________
Old 04-26-2012, 05:19 PM   #9
berti_00's Avatar
Drives: AMG
Quote:
are you saying we cant leave dipsticks in while driving??
__________________
Old 04-26-2012, 05:25 PM   #10
Drives: ML550
Quote:
No, the factory tool is not designed to be left in the engine while it's running. It is calibrated in milliliters, and you compare the reading on the dipstick to the chart that's published in the WIS. Based on the reading, you know how much oil to add or delete. It's very precise, and it's a good thing not to overfill this engine.
I wouldn't trust that a dipstick designed for use in another engine is calibrated correctly for the M113K engine. The only way I would trust it is to take measurements using my factory tool, set the oil fill level to perfect specification, and then check the reading on the ML430 dipstick. You could then mark that dipstick for the exact fill level required for the M113K engine.
Is the one you ordered designed to be left in the engine?
Old 04-26-2012, 05:37 PM   #11
berti_00's Avatar
Drives: AMG
yah its just a regular dipstick that stays in
__________________
Old 04-26-2012, 05:40 PM   #12
berti_00's Avatar
Drives: AMG
but i also came across this but this might be just to measure not one that stays in
http://www.ebay.co.uk/itm/Mercedes-B...d=336498219707
__________________
Old 04-26-2012, 05:46 PM   #13
Drives: ML550
In the interest of science, I'll spend $15 at my online parts supplier and buy the dipstick you mention, compare its readings to those of the factory tool, and report my findings. I'm old school and trust what I can see rather than relying on an electronic sensor which has been known to fail on occasion.
Old 04-26-2012, 05:55 PM   #14
berti_00's Avatar
Drives: AMG
id rather do the same thing... i dont trust no sensors
i just got a message on my dash "reduce oil level or something" i've had my oil changed about 2500 miles ago was measured twice with that measuring dip stick and was perfect so am thinking my sensor is failing... if so is this the one?
http://www.autohausaz.com/search/pro...Level%20Sender
__________________
Old 12-26-2012, 03:06 AM   #15
BBBSS's Avatar
Drives: 03 E55 AMG, 06 Harley Road King Custom 99 Ram 3500 Cummins, 97 Firebird Race Car, 88 Cutlass Project
Bumping this up. Anyone figure out a usable engine oil/trans dipstick?
BBBSS is offline   Reply With Quote
Old 12-26-2012, 09:57 AM   #16
moosejaw's Avatar
Drives: none
Quote:
Doesnt make sense but
http://www.ebay.com/itm/DORMAN-917-3...-/200812846531
honestly dont think the same dipstick fits all these vehicles.
__________________
moosejaw is offline   Reply With Quote
Old 12-26-2012, 11:56 AM   #17
Drives: 06 E55 AMG
I just ordered the factory dipstick 120 589 07 21 00
It does not seem to go all the way into the dip stick tube and appears to bottom out.
Is this typical? If so, how do you know it is in far enough? I have about 7 inches poked out of the top.
G
Gadget@URD is online now   Reply With Quote
Old 12-27-2012, 04:23 PM   #18
SPONSOR
loungn14's Avatar
Drives: Eurocharged Performance E55 Beast
pages/Eurocharged-Performance/248481410297 eurocharged
G
that is typical. All the MB tools (trans etc) do that...
Just jam it in there until it bottoms then take the reading....
__________________
Eurocharged Performance - Tuners of the fastest C32 / and fastest E55 .....
WWW.EUROCHARGED.COM
Check out our facebook page!
Email us: Sales@eurocharged.com
(281) 398-9700
Eurocharged now has 5 worldwide locations! Houston, Toronto, Hong Kong! South Africa and Boston
loungn14 is offline   Reply With Quote
Old 12-27-2012, 11:53 PM   #19
Drives: 07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
I have this one.
Amazon Amazon
Amazon (Links)Amazon (Links)
WHTEVO is offline   Reply With Quote
Old 12-28-2012, 07:44 AM   #20
Drives: 2006 E55 AMG
I have the transmission dipstick.. They're not the same right?
cwmateiuc is offline   Reply With Quote
Old 12-28-2012, 07:45 AM   #21
berti_00's Avatar
Drives: AMG
Quote:
Originally Posted by WHTEVO View Post
Does it stay in the car or its only to check and remove
__________________
Old 12-28-2012, 10:23 AM   #22
Drives: 2004 W211 E55K
Does it go all the way though or does it stick up like one of the other members said there's did? Im interested if this is the correct part.
__________________
bnzuovr is offline   Reply With Quote
Old 12-28-2012, 10:34 AM   #23
Drives: '03 SL500, '10 E350 sdn, '12 E350 sdn
berti_00, did above (ML's dipstick) work for you?
__________________
Current cars:
'03 SL500 Sport Slv/Blk on 20" HRE 544R & 20" OZ Opera PL
'10 E350 sdn Sport Wht/Blk Pano P1 on 19"
'12 E350 sdn Sport Wht/Almnd-Blk Pano P1 on 20" OZ Galileo III & 19"
Previous MBs:
'10 E550 cpe (will be missed), '09 E350 4matic, '03 E500, '02 ML500, '00 ML320, '00 CLK430, '00 E320 4matic, '99 CLK430
Most significant previous others:
'05 Audi A8 (a great automobile)
'01 Audi A6 4.2 Sport
'97 Toyota Supra
'90 Nissan 300ZX
'87 Mazda RX-7
threeMBs is offline   Reply With Quote
Old 12-28-2012, 11:37 AM   #24
MBworld Guru
Drives: 04 CL55, 13 Smart
My car came with a dipstick...
__________________
2004 CL55 - Tektite Grey / Anthracite
2013 Smart Coupe - Deep Black / Black
OCKlasse is offline   Reply With Quote
Tags
05, amg, buy, check, dip, dipstick, e55, factory, lasl, links, lowering, mercedes, oil, stick, w210, w211
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
