Sign in using an external account
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 03 e55 amg
mobil 1 e55
#2 |
Drives: Dirt Scooters
0w-40 is what Mercedes says to use.
__________________
![]() 10.51@132 on motor 1.52 60ft 10.52@135 on spray 1.61 60ft Tuned by Eurocharged. New build starts 11/26 |
#3 |
just bought 10quorts 0w40
__________________
![]() ECU/TCU V4 Tune (EuroCharged )540whp 565wtq |S/C Pulley|OEM 82mm TB S/Grinded|Belt Wrap Kit|NGK colder Spark Plugs|Split cooling system|EvoSport Intake Spacers|C63 exhaust|X-pipe|Kleemann Headers|Primary-Seondary CAT-Resenator Delete|K&N filters|Heat Exchanger|Supercharger Pump|TTM Air Scoops|Custom 4" intake|19" Concaved Wheels|L.A.S.L Lowering Links|JL-M CF Front Lip|JL-M CF Diffuser|Carlsson CF spoiler |2013 LED Mirrors Arrow type|Euro Command|12% headlight tint |Philips Headlights| |
#4 |
Drives: 2003 E55 AMG
You need 9 quarts of 0w40 Mobil 1 European Car formula. 9quarts=8.5Liters. Cheapest place to buy is Amazon or Walmart.
Hope this helps! |
#5 |
Drives: 03 e55 amg
#6 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
That would appear to be it. Look on the bottle to ensure it says approved against MB 229.5.
It is crucial that the product you use meets the AMG HTHS requirement if you want to protect your valvetrain.
__________________
![]() Llandudno, Cape Town, South Africa |
#7 |
Drives: W211 E55, W124 300TE
This, I get mine at the Mercedes dealer for 6.25. They sell it at walmart for 6.50 and 8.25 at Autozone.
__________________
#8 | |
Drives: slow
Quote:
Check with your local dealer. I got mine down under $5 a quart with a friends wholesale account.
__________________
![]() Ricer hoopty club member #2 Spending money I don't really have, on things I don't really need, to impress people I will never meet! On the way to creating the most ricer hooptie mobile... ever. |
#9 |
Drives: 03 e55 amg
#10 | |
Quote:
thanks thats good to know!
__________________
#11 |
Super Moderator
__________________
#12 |
Drives: 04 MB E55 AMG (MINE); 06 Jag XK8 Victory Edition Vert (HERS); 1997 Pontiac Sunfire (work mobile)
I think all Mobil 1 0W-40 sold in North America is the "European Car Formula".
http://www.mobil.com/USA-English/Lub...l_1_0W-40.aspx
__________________
#13 |
Drives: MB Master Tech. 04 S600, 91 240SX 1JZ swap (FOR SALE), 00 ML55, 98 C43-55 Swap With Blower!
Good info on Mobil 1 oils here
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
__________________
Only W220 on 20x12's!
#14 |
Drives: one car at a time
Have you guys found the dealerships are now using 5-40 instead of 0-40 ?
#15 |
Both are approved weights. FYI "most" dealers don't even use Mobil 1. There bulk oil and whet they sell over the counter are two different things. I have worked at 3 dealers and one used vavoline an the other two used cam2
if you get your car serviced (dealer or indy) tell them you want Mobil from the bottle and you want to see the empty bottles. It's due to cost. If they can save $2 a qt times how many quarts they use it adds up quick. It's not right, i know
__________________
| Tags |
| 2005, 5w30, amg, benz, e55, engine, hths, mercedes, mobil, mobile, oil, recommended, requirements, w210, w211 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
