Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-06-2012, 01:49 PM   #1
Jon2007E63P30's Avatar
Drives: 2007 E63 w/P30 and Eurotech CF Diffuser
Trunk - symptoms looking for a diagnosis
Somehow I think the only thing I will hear is crickets, but here goes...
All electronic systems in the trunk lid stop working as soon as it is a little past half closed. That includes:
3rd brake light
License plate lights
Auto Trunk opening - need to use the key
If the trunk is fully open, everything works fine.
My guesses:
1. A connector is loose in the wiring harness where is has slack to allow the trunk to open and close.
2. Washed the car with a pressure sprayer yesterday and got water into some module in the trunk lid. The water moves in the module and stops shorting thngs out when open.
Wisdom from my fellow AMG fanatics!! And help. I am not great with startech. Also, any advice on removing these panels. Links to any info would be appreciated.
Thanks,
Jon
To remove this ad, register today or login if you already are registered!
__________________
Jon2007E63P30 is offline   Reply With Quote
Old 05-06-2012, 01:59 PM   #2
Drives: 1998 C43 with 55 swap/1990 Ranger 347 swap
AMG_TECH
The wiring harness breaks by the lower part of the hinge.
tri-star tech is offline   Reply With Quote
Old 05-06-2012, 02:23 PM   #3
Quote:
Given your name, and clarity of your statement, I will get back to you if it really was "nothing but net"
This also matches my spidey senses.
__________________
Old 05-06-2012, 06:29 PM   #4
tri-star tech. Nothing but net. I totally need to eat my statement about "crickets"
Here are the pics. Now I know how to get to the top of the shock towers as well! First two pics are just to let everyone see what is in there and what we are talking about. The last is the actual break. In the first two pics, you can see a little slack in the harness as it goes along the trunk arm. I am going to remove the slack which will move the point where the harness needs to bend. I will also try to provide more relief in the bend.
For the repair, might have to add some wire, but no big deal. I do need to determine the potential of the wire. I am hoping it is the ground connection. I reason to believe this because one break is effecting 3 systems.
More pics when done. Oh yea, the wiring harness was dirty with black adhesive from the cloth electrical tape. This is after cleaning with goof-off and alcohol.
Click the image to open in full size.
__________________
Old 05-06-2012, 06:33 PM   #5
.trunzx's Avatar
Drives: '03 E55
Exact same thing happened to me. Really annoying but at least it's an easy fix.
__________________
.trunzx is offline   Reply With Quote
Old 05-06-2012, 09:20 PM   #6
So fix finished. Went with a mechanical splice. You can argue that it is not as reliable as soldering, but it was quick and I had the proper size for the wire guage.
Used a lot of fiberglass tape to give the harness more stiffness resulting in a large diameter bend. Here is the result, including a video in operation. Yes, that is my head peaking in waiting for the camera timer to take the photo.
__________________
Old 05-06-2012, 09:34 PM   #7
Drives: 211-55
Very poor design by MB but thanks for the fix and video.
__________________
PC Tune * 180mm * 82mm * K&N * JohnsonCM30 * PLM shorties * X-pipe * Secondary Cats Removed * Resonator Removed * Phen Spacers * -10 deg
cahiil55k is offline   Reply With Quote
Old 05-06-2012, 11:29 PM   #8
Bellevue_E55's Avatar
Drives: 2006 Mercedes E55
same happend to mine I spliced it too and it lasted another year and then failed again. THis time I remembered I had an extended warranty and they are covering it -- woo hoo
__________________
2006 E55
Stock - Iridium Silver with Pano Roof, Parktronic, Dynamic Seats, Ventilated Seats, Keyless to Go
Mods- X-Pipe, EuroCharged/Shardul Exhaust, Carlsson Lowering Module, K&N Filters, trunk subwoofer, Eurotek CF rear valence, Forgestar 19" Wheels
My car is for sale - http://mbworld.org/forums/mercedes-v...s-29k-obo.html
Bellevue_E55 is offline   Reply With Quote
Old 05-07-2012, 12:37 AM   #9
Drives: '06 E55 K2
Great thread and reference for us.
Congrats on the fix.
slownrusty is offline   Reply With Quote
Old 12-31-2012, 04:38 PM   #10
Drives: 2005 e55 amg, '03 Ducati Monster
Grantmarkdavies Grantmarkdavies
Had the same issue and just fixed it, broken ground wire.. Great thread, thanks!
http://www.flickr.com/photos/grantma...7632393860361/
__________________
2005 E55 AMG
2002 E55 AMG
2003 Ducati Monster 800 Dark i.e.
Past rides
2003 Corvette Z06
1999 Mitsubishi Eclipse GSX
1994 Mitsubishi 3000GT SL
1993 Eagle Talon TSI
realien is offline   Reply With Quote
Tags
09, 2006, benz, cover, e350, e55, harness, lid, mercedes, remove, replacing, symptoms, trunk, wire, wiring
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
