Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-03-2012, 10:10 AM   #1
vioilio's Avatar
Drives: 2003 E55 AMG
What do you all think of this cooling setup?
Is it going to drop significant amount of IAT's? All opinions are welcome!
Click the image to open in full size.
To remove this ad, register today or login if you already are registered!
vioilio is offline   Reply With Quote
Old 06-03-2012, 10:15 AM   #2
Drives: E55
It's called a split cooling system and does help, do a search, many threads on it
Hulk is offline   Reply With Quote
Old 06-03-2012, 10:18 AM   #3
Drives: 2005 E55 AMG
I tried fitting another stock h/e in my car and there was no where to put it.
__________________
Awaiting for the moment in my life where I can get back to modifying cars. Soon...hopefully.
GT-ER is offline   Reply With Quote
Old 06-03-2012, 10:21 AM   #4
vioilio's Avatar
Quote:
I know it is called split cooling setup. I'm more concerned about the 2 inter coolers in series.
Old 06-03-2012, 10:23 AM   #5
vioilio's Avatar
Quote:
Actually there is a way. I'm working on it right now. I can post some pictures when done.
Old 06-03-2012, 10:28 AM   #6
SPONSOR
shardul's Avatar
Drives: 2003 W211 E55, 2003 W220 S600
I have had my setup for the last 3 years
Aux. Heat Exchanger, Split Cooling - Done PICS
__________________
E55
shardul is offline   Reply With Quote
Old 06-03-2012, 10:34 AM   #7
Quote:
With a second oem heat exchanger? Can't wait to see it.
__________________
Old 06-03-2012, 10:35 AM   #8
vioilio's Avatar
Exactly what i'm doing right now but with evosport H/E (my old setup) + new custom H/E. I think I might even change the evosport one with my custom one and mount it behind, and then add the Buckhead Imports H/E and put it infront.
Old 06-03-2012, 10:37 AM   #9
Drives: E55
Yes I remember that lol
Old 06-03-2012, 10:54 AM   #10
vioilio's Avatar
An one more idea....
Old 06-03-2012, 11:21 AM   #11
moosejaw's Avatar
Drives: none
i have that same exact setup
__________________
moosejaw is offline   Reply With Quote
Old 06-03-2012, 11:55 AM   #12
Drives: 03 C32, 06 CLS55
The yellow return line in this pic is wrong! It is supposed to go back to the second tank or you will lose coolant on the IC circuit:112:
__________________
CLS55
ASP 180mm Pulley, 82mm throttle body, 550cc injectors, BMC headers High flow CATs X pipe 2nd CATs removed, PLM H/E Johnson pump Separated coolant, Lower by STAR + some mods, 20" 20mm spacer, Euro Command video + backup camera enabled. EC ECU/TCU dyno tune.
C32
LET 185mm Pulley, LET headers, CODE3 Intake, CODE3 Intercooler, 2.5 Modified Intake Plenum, 2nd CATs Removed, Quattro tips, Separated IC coolant, LET Dyno Tune
And big fat 5bls heavier wheels on 275
CLKCLK is offline   Reply With Quote
Old 06-03-2012, 01:24 PM   #13
RedBullJnky's Avatar
Drives: One Fast E55 AMG Eurocharged stage 3+
I don't think my cooling set up works. My IATs never go over 110. Bwahahahah!!!!!!!
__________________
"don't think about it, be about it....don't be scared.... No excuses, No apologies..."
RedBullJnky is online now   Reply With Quote
Old 06-03-2012, 02:34 PM   #14
jnash's Avatar
Drives: 03 S55, 73 Norton Commando, 00 GSXR750 track bike
Jim Nash https://www.facebook.com/profile.php?id=706625563
The S55 (w220) has two HE in series. The bottom one which stock is smaller than the E55's, and then it plumbs directly into a thinnish half-height in front of the main radiator and is as wide. Just upgraded the bottom one.
jnash is offline   Reply With Quote
Old 06-03-2012, 02:38 PM   #15
grantwoodtx's Avatar
Drives: W212 E63
http://www.linkedin.com/in/grantwoodtx
Those are not INTER COOLERS!
grantwoodtx is offline   Reply With Quote
Old 06-03-2012, 03:25 PM   #16
Drives: 2003 E55
I have always heard and most women will confirm that 1 large one is better than 2 small ones.
__________________
__________________________________________________ _______________________
Jakpro1 is offline   Reply With Quote
Old 06-03-2012, 04:42 PM   #17
Quote:
So one big turbo is better than two smaller one? Lol
__________________
CLS55
C32
Old 06-03-2012, 04:50 PM   #18
Drives: E55
Quote:
It is for the most power
PACougar is offline   Reply With Quote
Old 06-03-2012, 07:09 PM   #19
vioilio's Avatar
Quote:
My bad! They are heat exchangers!
Old 06-03-2012, 08:47 PM   #20
Drives: 06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Renntech has done the same on my car , except I havent been able to locate the extra resevoir... can the two HE be plumbed without it ? .. I Think they kept the OEM one and added another BEHR one i cant see the part number of the second one so I am not sure if the two are identical ..but I can find out ... if there is room to change the OEM to the EC one, keep the second .. that " I think " would be better .
maxwerks is offline   Reply With Quote
Old 06-03-2012, 08:48 PM   #21
Quote:
E, are you kidding ... what is your secret ?
Old 06-03-2012, 09:17 PM   #22
Drives: E55
Secret
Old 06-03-2012, 09:26 PM   #23
no secret, just different. Gimme a min................
Okay, here you go.
I have a Eurocharged HE up front with a Meziere pump, a 3.5 gal trunk tank with a Rule2000 pump, AND.......(secret)...a Cobra HE welded under the trunk. All 3/4 hoses and a 1.5 gal meth tank. Meth only comes on at 11lbs of boost.
Now the other secret is the route it runs. Some people will say its wrong, but It works with my setup.
It goes from trunk tank - SC - front HE - Cobra (rear) HE - trunk tank
Example: In 89 degree weather we filled the trunk tank with ice. We did a fourth gear pull on the dyno to 181mph and when the car was back at idle we opened the trunk tank and checked (with laser thermo) the temp of the water in the tank. It was 69 degrees and no ice left. Also my surge tanks are cold to the touch after a pull (due to meth). IATs through the entire run NEVER went over 110.
My 11.03 run at Silver Dollar Raceway was done in 100 degree weather or should I say "HEAT".
__________________
Old 06-03-2012, 10:21 PM   #24
benz_addict's Avatar
Drives: V12TT
You guys should look into the CL65 H/E with the fan attached to it. I have that setup + lower valance mount H/E + Stock H/E with the new Bosch pump. Best system so far :Y
DIY: split S/C cooling for CL55 S55 SL55
__________________
S600 V12TT - S65 cluster, S65 exhaust, Brabus ABC ELM, CL65 gloss black wheels, delimited
benz_addict is offline   Reply With Quote
Old 06-03-2012, 10:23 PM   #25
jnash's Avatar
That is very ingenious.
Tags
c32, cl65, cooling, e55, exchanger, heat, hoses, intercooler, system, tank, tanks, trunk, w211, water, works
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
