Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-04-2012, 04:08 PM   #1
Peter_02AMG's Avatar
Drives: 2007 E63 / 2002 E55K (SOLD)
Need help replacing RH O2 sensor
How hard is it to replace the passenger side up stream O2 sensor?Any advice or guidence is greatly appreciated.
To remove this ad, register today or login if you already are registered!
__________________
EVOSPORT ROTORS | KW V2 COILOVERS
Peter_02AMG is offline   Reply With Quote
Old 07-04-2012, 04:52 PM   #2
SPONSOR
shardul's Avatar
Drives: 2003 W211 E55, 2003 W220 S600
Pretty easy use a open end wrench to break it loose
shardul is offline   Reply With Quote
Old 07-04-2012, 07:05 PM   #3
Drives: haters crazy
Or use the o2 specific socket
__________________
Ricer hoopty club president
Run your car not your mouth
blackbenzz is offline   Reply With Quote
Old 07-04-2012, 07:17 PM   #4
gaspam's Avatar
Drives: 2006 MB E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Quote:
its super easy... most time consuming part of the job is jacking the car up and putting it on jackstands..
they just unscrew with wrench and unplug just a bit further up.
__________________
2006 MB E55 - 180MM ASP Pulley, EC long tube headers, EC H/E, updated Bosch IC pump, DDM HID headlights and fogs
2001.5 Audi B5 S4 stage3+ w/meth (489 awhp)
gaspam is offline   Reply With Quote
Old 07-04-2012, 07:25 PM   #5
novae500's Avatar
Drives: W211
not too bad if you have one of those 02 open ended wrenches for 02 sensor. Just make sure you hit it with some PB blaster in case you havent opened it in a while.
__________________
05 E55: 496rwhp / 530 torque, MBH headers, Renntech 168mm, Smaller s/c pulley, EC H/E, CF Intake Tubes, TTM Scoops, HRE 547rs, OE Tuned
06 E500 4matic: wife's
novae500 is offline   Reply With Quote
Old 07-04-2012, 07:37 PM   #6
mpwr's Avatar
Drives: 01 E39 M5 SOLD 07 E63AMG Mazda3 Hatch
Quote:
+1 with the o2 specific socket very easy.
__________________
2007 E63 Arctic White w/Pano-Fully Loaded-Renntech ELM-Renntech AirBox Illuminated AMG Doorsills-Hardwired V1-Blinder M20-Mario Badge-Power Folding Convex Mirrors-Reus Audio system-35% Tint-14.1 DTM AMG P30 steering wheel-20" ADV1 Flow Spec Finish Satin Black-Rear seat AMG badges-Yellow AMG Calipers-TTM LT Headers Cat Deleted X-pipe Eisemann Race EuroTeck CF Front Lip, Rear diffuser & decklid spoiler-Painted Black Grille (Plus one Wrap in 3M Dinoc Carbon) Blk emblems EvoSport Light Weight Rotors
mpwr is offline   Reply With Quote
Old 07-04-2012, 09:09 PM   #7
Dealer raped me for the left side a few week ago $702, still hurting. My right side just went dead today. I think I will try to replace it myself this time.
Do you have to program the new sensor to adapt or just plug and play?
__________________
Old 07-04-2012, 09:43 PM   #8
SPONSOR
shardul's Avatar
It is plug and play
__________________
E55
Old 07-04-2012, 11:43 PM   #9
Former Vendor of MBWorld
Drives: FTP-E55///AMG
FabtechPerformance,LLC
Peter like the rest of the guys said Un clip the o2 sensor and break it loose, Thread the new one on and plug it back in. Be sure to clear the codes before startup. sounds like something is causing them to burn out pre-mature. have you done any mods or tune lately? maybe it was just a fluke.
FT-Performance is offline   Reply With Quote
Old 07-05-2012, 10:31 AM   #10
Quote:
I didn't have any problem till I got the ARH LTH installed and EC tune. My car started to throwing CEL left and right. Multiple cylinders misfired on the left side, my car was hesitating so badly I couldn't get it pass 40mph. Everytime the car come to a stop it shake so badly it want to stalls, black smoke and unburnt gas fumes was coming out of the tail pipe. Limp my way to the local stealer and they replaced a dead left side O2. Run fine for a few week now I'm getting code for the left side, same symptoms. Maybe it just a fluke like you said.
__________________
Old 07-05-2012, 10:35 AM   #11
novae500's Avatar
Drives: W211
Were the o2 sensors wired correctly? There are two and white goes to the first and black to the second o2 in the header , but this is for the e55. If you interchange them in the header, can cause CEL issues.
__________________
Old 07-05-2012, 12:29 PM   #12
Quote:
Yes, the Stealer checked all the O2 sensors and it all working except the dead one. On E63 you will know right away if they are switched backward.
__________________
Old 07-05-2012, 12:33 PM   #13
gaspam's Avatar
+1 ^ this happened to me as the shop that installed my headers reversed the o2 sensors and i kept throwing codes so decided to replace o2's and when i got under car i noticed the 02's were in the wrong spot (downstream were in the upstream position and upstream where in the downstream position)... i reversed them and car was fine and sent new o2s back for refund
O2 sensor placement problem
__________________
Old 07-05-2012, 01:36 PM   #14
SPONSOR
shardul's Avatar
Can you check your long term fuel trims
Old 07-05-2012, 01:59 PM   #15
Quote:
Last time I had it check with a STAR before the left side went dead everything was normal. I have no way of checking it now.
__________________
Old 07-05-2012, 02:11 PM   #16
SPONSOR
shardul's Avatar
can you check them on the driver side
__________________
E55
Old 07-05-2012, 02:19 PM   #17
mpwr's Avatar
Hey Peter we have the same car and I was one of the first one with the ARH LTH and knock on wood never throw a CEL. The only thing different we have different tuner. I have the OE tune on mine. Hope you can get to te bottom of the problem so you could enjoy the car.
__________________
Old 07-05-2012, 04:15 PM   #18
Quote:
You're lucky man..I hate having to deal with this *****..does your number 8 pipe rub the steering column under load? especially when you make a turn and hit the gas?
__________________
Old 07-05-2012, 05:46 PM   #19
SPONSOR
shardul's Avatar
i would check the motor mount before contacting the manufacturer
__________________
E55
Old 07-05-2012, 06:57 PM   #20
mpwr's Avatar
I get some vibration under load but not sure its from the steering column I have the Eisemann race mufflers and the passenger side is close to the body. I don't know how close the steering knuckle is to the #8 pipe you can remove that knuckle and just use a nut and bolt in the column. I have seen Bruce at TTM do it and seem to work.
__________________
Old 07-13-2012, 11:32 AM   #21
Finally got the O2 sensor put it. It was much easier than I thought it would be. Everything is running great. Just so you E63 guys know the front O2 sensor are the same for left and right even though the harness insulator are different color (black or dark green). I thought they sent me the wrong part cause the harness was a different color but the part number on the sensor are exactly the same.
__________________
Old 07-13-2012, 01:05 PM   #22
novae500's Avatar
Drives: W211
great to hear you sorted out the codes, its aggravating to install mods and have a code pop up.
__________________
Tags
2008, change, e55, installation, m5, mb, mercedes, o2, ox, oxygen, replace, reprogram, sensor, upstream, world
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
