Sign in using an external account
| W211 AMG Discuss the W211 AMG's such as the E55 and the E63 |
LinkBack | Thread Tools | Search this Thread |
Rating:
Display Modes |
#1 |
Drives: 2006 MB E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
asp pulley wobble
__________________
2006 MB E55 - 180MM ASP Pulley, EC long tube headers, EC H/E, updated Bosch IC pump, DDM HID headlights and fogs 2001.5 Audi B5 S4 stage3+ w/meth (489 awhp)
#2 |
Drives: 2006 E55 AMG
I see what you are refering to, but it does not look that bad to me. When did your car start throwing belts? Did it throw belts before you touched any of the pullies?
__________________
CornFed E55 (e85)/Meth -10.84 @ 127mph-w/1.65 60ft-TUNED by TONY@BIP Slammed on VOSSEN CV7's http://www.youtube.com/watch?v=HHv4jhA2lyc http://www.youtube.com/watch?v=PZHxMP9BrOM http://www.youtube.com/watch?feature=youtube_gdata_player&v=96DNQbnYuBE |
#3 | |
Quote:
thought it was belts at first so ec recommended trying diff brands which i did to no avail... then i noticed a little scoring on the top of the belts (smooth side) so though tensioner pulley might be the culpret since its the only pulley that touches th smooth side of belt, so switched to ASP tensioner pulley to no avail and now it looks kinda wobbly as in the video, but i couldnt honestly remember what the original MB tensioner pulley spun like so i had no ref as to if this is normal for the asp pulley or not ![]() i def am going to order a new actual tensioner unit that the pulley attaches to because it seems its not holding the dayco belt tight enough... really annoying when you are trying to pull away from someone and then all the sudden car looses like 200hp cuz a belt came of
__________________
#4 |
I just sold my spare oem tensioner, I would have let you have it for next to nothing man. My OEM idler pulley and tensioner does vibrate a little back and forth, but the actual pulley has no wobble if that makes sense.
It sounds like the crank pulley is the culprit, if this issue started right after install. Could you put a vid up of the crank pulley at idle? Did you inspect the grooves of the welded on outer to make sure they were smooth, and no knicks?
__________________
CornFed E55 (e85)/Meth -10.84 @ 127mph-w/1.65 60ft-TUNED by TONY@BIP Slammed on VOSSEN CV7's http://www.youtube.com/watch?v=HHv4jhA2lyc http://www.youtube.com/watch?v=PZHxMP9BrOM http://www.youtube.com/watch?feature=youtube_gdata_player&v=96DNQbnYuBE Last edited by chawkins2001; 07-13-2012 at 04:31 PM. |
#5 |
Drives: Dirt Scooters
Change the tensioner. My car did it 3 times on stock pulley. I changed the tensioner and put ASP pulley on and it was fine after that.
__________________
![]() 10.51@132 on motor 1.52 60ft 10.52@135 on spray 1.61 60ft Tuned by Eurocharged. New build starts 11/26 |
#6 |
Former Vendor of MBWorld
Our ASP Tensioner Pulley has some play in it, But the Car does not throw belts.
#7 | |
Quote:
it def started right after pulley install but i think that could also be that on stock belt and pulley the tensioner was maybe bad but tight enough and then when changing to the larger pulley and belt combo may have put the tensioner in a range where its not giving enough pressure on the belts allowing them to usually hop off and occasionally shred... usually when it happens i pull over and the belt is just sitting by the fan shroud untouched and fine and i just pop it back on... i put the belt on in about 5 seconds now from doing it so many times lol
__________________
#8 |
hopefully that works for me too as its getting super annoy and seems always to happen when a m5 or 335i wants to race me lol murphy's law
__________________
#9 |
Drives: One Fast E55 AMG Eurocharged stage 3+
Let me know if I can help. I'll see what I have at Nemo's shop.
__________________
![]() "don't think about it, be about it....don't be scared.... No excuses, No apologies..." |
#10 |
Drives: E55
My ASP tensioner pulley had some wobble as well, so I tossed that junk and put a new OEM tensioner unit on.
#11 |
Drives: No longer stock '06 E55, A3 3.2 Quattro, LRD3 HSE
I guess sometimes the merc guys do know better than aftermarket.
__________________
Rgds Steve 2006 E55 Iridium Silver [X] Modified |
#12 |
Drives: 06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
what are the supposed advantages of the ASP tensioner over the OEM one , forgive me but I am l am a late comer to the S/C M113
#13 |
Drives: '06 E55 K2
#14 | |
SPONSOR
Drives: 2003 CL55
Quote:
The pulley just bolts to the tensioner spring housing, so any play in that spring housing can make the pulley look like it is wobbling a little.
__________________
Darton MID sleeved, Forged Mahle custom race pistons, Ported race heads, custom Headers, UPD 3000 stall converter W/#2 pump, EC tune, 725cc Injectors, Bosch 044 pump, 8an fuel line, custom fuel rail, UPD 83mm SC pulley and beltwrap kit, 185mm CP, Aux. HE, Trunk tank w/rule 2000 pump, Mezeire pump, ASP idlers, Aluminum rotor hats, C6 battery.
#15 |
Did you do the full idler pulley kit all 3 pulleys!! I have them too and now feel kinda scared to o have them installed... I dnot have time to go to shops back and fourth..
__________________
![]() ECU/TCU V4 Tune (EuroCharged )540whp 565wtq |S/C Pulley|OEM 82mm TB S/Grinded|Belt Wrap Kit|NGK colder Spark Plugs|Split cooling system|EvoSport Intake Spacers|C63 exhaust|X-pipe|Kleemann Headers|Primary-Seondary CAT-Resenator Delete|K&N filters|Heat Exchanger|Supercharger Pump|TTM Air Scoops|Custom 4" intake|19" Concaved Wheels|L.A.S.L Lowering Links|JL-M CF Front Lip|JL-M CF Diffuser|Carlsson CF spoiler |2013 LED Mirrors Arrow type|Euro Command|12% headlight tint |Philips Headlights| |
#16 |
sorry was out of country for a little while so didnt have chance to upload video of crank pulley, but here is is now... crank pulley appears to be fine from what i can see... is this how others aftermarket pulleys spin or is it more true ?
![]() and mine is still throwing belts but i got a tensioner from shardul that i will install probably tonight and see if that fixes it, if not then probably just going to go back to stock pulley and either get the weistec blower when hp/tq, etc numbers come out and when someone else has run it for a while... or i will just sell the car if not.
__________________
#17 |
Drives: E55 w/ goods, Z32 Project underway
I threw belt after belt with my pinned 180mm pulley. I think it had something to the do with the lip design as the pulley itself was true. Gates belt would not last over 500 miles, while Dayco would last a bit longer. I think total I shredded over 7 belts. Not a single tossed pulley with my 200mm welded unit.
__________________
200mm welded ASP pulley, Eurocharged TCU/ECU tune, shorty headers, Quaife LSD, H/E, '10 Bosch IC_pump, ,80mmTB grind, Primary/Secondary cat & resonator deletes, 550cc Bosch FI, Auto folding convex mirrors, 21lb Braille battery.FT-P IC tank, TTM scoops, Loop'd fuel rail. Lightweight Forgestar 19s. E63 front, conv. 105lbs total weight savings. C4 Compact. Next: Killer Chiller Nissan Z32 project, stock '87 944T, GX470, Vette, Truck
#18 | |
Quote:
super ducking annoy
__________________
#19 |
i changed the tensioner assembly last night so will see if that works.
when changing it i also inspected crank pulley further and noticed a little nick on the top of the outer ring as seen in the pics below... it is kind of scratchy (for lack of better word lol) but its on outer ring above where the belt seats so i wouldnt think it would affect anything... thoughts ? ![]() ![]() also on the belts this seems to happen to all my belts where a new belt will have abrasion and exposed inner wires after no time from being installed... i dont think that is normal ![]()
__________________
#20 |
The belts I've used always have exposed strands of fabric on them. Just a thought. Hopefully you get it figured out.
__________________
#21 | |
Quote:
all the 51.4 gates belt have been shredding so if this one doesnt then i think the tensioner was the culprit, but if it shreds like all the rest then i gotta believe its the pulley as i never threw a belt before the 172M pulley was added in march.
__________________
#22 |
Drives: W211
5,000 miles since i have a 168mm crank pulley and see strands of fabric on the edges of my sc belt. So may be just common to see this on the belt
#23 |
thanks bro will have to stop by next time in am in miami
__________________
#24 |
Drives: 05 White Pano E55, 437whp Audi A4
I have been having belt shredding issues too, not sure if coincidence or not but I had a squeak which I thought was pullies (it turned out to be the belt) so I bought the ASP set and shredded the belt a couple days later after driving from Jacksonville to Miami for the Eurocharged tune day. Got another belt on there (RedBullJnky hooked me up with his off his car since he was leaving it at the garage) and it lasted a few trips through Florida (1400 miles?) then it shredded (both Gates 51.5). Ordered a Napa belt (think made by Gates) and drove from the Keys to Jacksonville and a little around so maybe 700 miles so far then left town so not sure how that one is going to hold up. Oh and my belts also get a frey on the inside edge closest to the engine.
Wonder if I need a new tensior and that could be my issue?
__________________
White Pano E55, 480whp 497wtq *old setup 11.69@120 on 19s* -David-
#25 |
at least i am not the only one lol makes me feel a little better!
![]() i think the solution is weistec blower and back to stock pulley or 168mm depending on what weistec's numbers come out to be on hp/tqotherwise i am giving up on s/c cars and sticking with turbos
__________________
| Tags |
| asp, belt, cls55, diffuser, e55, idler, mercedes, play, pulley, pully, renntech, style, suppose, tensioner, wobble |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
