Go Back   MBWorld.org Forums > Mercedes-Benz AMG Vehicles > E55 AMG, E63 AMG (W210, W211, W212) > W211 AMG
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-23-2012, 12:32 PM   #1
Drives: 2004 e55, 2006 gmc 3500 van( for work )
Looped Fuel Rail Questions???
I just bought a fuel rail that I plan on looping. I just needed to know if there are any specific measurements or angles that I need to follow. Also I am not sure what injectors I should run, I was told the 550cc but no brand. Please let me know what you think. Thanks
https://lh4.googleusercontent.com/-j...4/s640/006.JPG
To remove this ad, register today or login if you already are registered!
2004RennTechE55 is offline   Reply With Quote
Old 07-23-2012, 01:40 PM   #2
moosejaw's Avatar
Drives: none
PM grantwoodtx if he is still on here
or look for one his DIY threads. Its very useful.
__________________
moosejaw is offline   Reply With Quote
Old 07-23-2012, 01:42 PM   #3
Bramage's Avatar
Drives: E55 AMG
TTM Makes a kit that will eliminate the guess work. Beyond that, you are going to get a lot of varied opinions. I would not wing a project like this. If you do it wrong, it could be problematic.
If you opt to go this route, you will probably need to pull the supercharger, and have the rail fabricated to fit under it. The clearance is VERY tight.
As a TTM fan boy, I would say: Call Bruce.
__________________
Bramage is offline   Reply With Quote
Old 07-23-2012, 02:25 PM   #4
Drives: E55
^^^^^ +1
He's the best!
Hulk is offline   Reply With Quote
Old 07-23-2012, 03:16 PM   #5
kompressede's Avatar
Drives: 05' E55, 12' E350
Just give Bruce a call. All the guess work is done already.
kompressede is offline   Reply With Quote
Old 07-23-2012, 03:35 PM   #6
Drives: 03 e55
Fabtech also sells a quality looped rail setup.
E55amg/FD3S is offline   Reply With Quote
Old 07-23-2012, 04:28 PM   #7
moosejaw's Avatar
Drives: none
The most cost effective way
Fuel Rail DIY
or if you like watching dollar bills swirl around porcelain, then by all means entertain one of the above options. I personally like seeing my dollar bills going into the gstrings of the performers at the local ballerina club.
__________________
Old 07-24-2012, 12:44 AM   #8
pearlpower's Avatar
Drives: E55 w/ goods, Z32 Project underway
Very easy to deal, just find a good welder. Have done 3 of them now, all leak proof, no issues. If you look at my photos in the link above you will see how tight the right angles are on each end. Otherwise straightforward. (No PMs for request please)
__________________
200mm welded ASP pulley, Eurocharged TCU/ECU tune, shorty headers, Quaife LSD, H/E, '10 Bosch IC_pump, ,80mmTB grind, Primary/Secondary cat & resonator deletes, 550cc Bosch FI, Auto folding convex mirrors, 21lb Braille battery.FT-P IC tank, TTM scoops, Loop'd fuel rail. Lightweight Forgestar 19s. E63 front, conv. 105lbs total weight savings. C4 Compact. Next: Killer Chiller
Nissan Z32 project, stock '87 944T, GX470, Vette, Truck
pearlpower is offline   Reply With Quote
Old 07-24-2012, 01:11 AM   #9
Former Vendor of MBWorld
Drives: FTP-E55///AMG
FabtechPerformance,LLC
Pmed
Click>> http://mbworld.org/forums/e55-amg-w2...ors-click.html
Click the image to open in full size.
FT-Performance is offline   Reply With Quote
Old 07-24-2012, 02:30 AM   #10
tbal's Avatar
Drives: Haters crazy
Quote:
Fuel Rail DIY
Straight goods
__________________
PB 11.65@123.16mph 1.74 60'
tbal is offline   Reply With Quote
Old 07-24-2012, 04:30 AM   #11
AgSilver's Avatar
Drives: 2004 E55,2007 CLK63,1969 300SEL6.3,2011 ML350CDI,2005 ML400 CDI,1977 Ferrari 400GTC4,914-6
AgSilver is offline   Reply With Quote
Old 07-24-2012, 07:58 AM   #12
chawkins2001's Avatar
Drives: 2006 E55 AMG
I was one of the first to sport the TTM fuel rail, been on for a year and a half, and has run flawlessly. Got 1000cc injectors in mine to boot.
__________________
CornFed E55 (e85)/Meth
-10.84 @ 127mph-w/1.65 60ft-TUNED by TONY@BIP
Slammed on VOSSEN CV7's
http://www.youtube.com/watch?v=HHv4jhA2lyc
http://www.youtube.com/watch?v=PZHxMP9BrOM
http://www.youtube.com/watch?feature=youtube_gdata_player&v=96DNQbnYuBE
chawkins2001 is offline   Reply With Quote
Old 07-24-2012, 10:17 AM   #13
Drives: shrimp boat
Like Dane and Craig said, there are options out there beside doing it yourself. It's a precise measure, too long or too short it won't fit. And if you were to do it yourself, may as well take an extra step and move the feed point.
Forrest Gump 9 is online now   Reply With Quote
Old 07-24-2012, 10:27 AM   #14
SPONSOR
shardul's Avatar
Drives: 2003 W211 E55, 2003 W220 S600
+1 on moving the feed point
__________________
E55
shardul is offline   Reply With Quote
Old 07-28-2012, 01:43 AM   #15
SPONSOR
TTMotorsports's Avatar
Drives: Whatever we're tuning!
Tuning Technology Motorsports Bruce Bejsovec
Send a message via AIM to TTMotorsports
Here is the thread that grantwoodtx posted:
Fuel Rail DIY
As you can see there was never a follow up of his finished rail since the fittings in the picture, which was reverse engineered on PSC, are full swivel fittings that DO NOT WORK with the modified rail because of clearance issues unless you use an AN6 fitting which causes inconsistent fuel pressure to all of the injectors.
The TTM modified rail, which has a provisional patent filed with the US Patent Agency, uses AN8 fittings which is the same size as the OEM rail and produces consistent fuel pressure to every injector unlike the rail that uses AN6 fitting and AN6 stainless steel fuel line.
Here is the prototype TTM Fueling Kit that was tuned and reviewed by Jerry from Eurocharged in early 2011 but was originally purchased by the CLS owner in late 2010 and waited for Jerry to come to FL for tuning:
TTM Injector and Fuel Rail – 3rd Party Review!!
It took us at TTM a couple of months, with a M113k engine on the stand and multiple configurations, to develop the best solution to the #8 cylinder fuel starvation issue, It is common knowledge now but TTM was the first company to address this issue and we continue to have the best products available.
The TTM Fueling Kit(modified 100% new OEM rail, AN8 stainless steel fuel line, TTM proprietary injectors and pig tails) is available for $1100 and we are proud to have in excess of 50 kits on the M113k engine throughout the world.
Imitation is the best form of flattery.
__________________
TTMotorsports is offline   Reply With Quote
Old 07-28-2012, 01:53 AM   #16
SPONSOR
Thank you Dane.
Quote:
Originally Posted by Hulk View Post
^^^^^ +1
He's the best!
Thank you Steve and also for letting me fix your imitation TTM fuel rail..
Quote:
Thank you Vinny.
Quote:
Originally Posted by AgSilver View Post
Thank you Steve. Steve is the original modified fuel rail guru and one of the most experienced guys on this forum.
Quote:
Thanks Craig.
__________________
Old 07-28-2012, 10:55 AM   #17
e55amgrocket's Avatar
Drives: Dirt Scooters
Not 100% true info but the looped rails do help. The real problems are the feed location and the rail not having enough volume to keep injectors with constant and stable fuel pressure. This was tested with stock and looped rails. Sneak peek of the real solution below. Inside diameter larger than -8AN (5/8) fitting that connect the crossover's. Rear crossover will have the inlet in the middle. Rail itself will be able to support well over 1000hp for those looking to push the limit
Looped Fuel Rail Questions???-photo-20-.jpg   Looped Fuel Rail Questions???-photo-21-.jpg
__________________
10.51@132 on motor 1.52 60ft
10.52@135 on spray 1.61 60ft
Tuned by Eurocharged. New build starts 11/26
e55amgrocket is offline   Reply With Quote
Old 07-28-2012, 01:47 PM   #18
pearlpower's Avatar
Quote:
Looking good, perhaps you should 'patent' that too.... LOL. Looking forward to more of this.
__________________
Old 07-28-2012, 03:01 PM   #19
WOW Steve that looks Hawt!!! Nice work
Old 07-28-2012, 03:10 PM   #20
Quote:
Yea good idea. Seems so to be a lot of "misleading" information about fuel rails and the fuel problems we have. I actually decided to put some $$ out and have stock and looped rails tested to see what was going on. A looped rail is better than stock yes but the problem is the inlet on the drivers side and the rail itself not having enough volume inside. The talk of "proprietary injectors" And using a stock rail on a modded engine is certain death is a scare tactic. How did I use a stock rail making 620+hp? The 550cc EV14 injectors can be found at many different injectors places and are just Bosch EV14 injectors that are modified to flow 550cc. There's a lot of lies that go around here to scare people I guess.
__________________
Old 07-28-2012, 08:44 PM   #21
Drives: shrimp boat
Those rails look goog Steve.
Tags
2004, amg, c32, e55, fuel, injectors, looped, mercedes, pressure, rail, rails, system, tank, ttm, w211
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
