Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes Benz E Class AMG: How to Replace Brake pads/calipers/rotors
Step by step instructions for do-it-yourself repairs
Common replacement and maintenance parts - all in one thread
#101
a friend of mine got a set of these on his SLK - they look pretty darned nice...
Spyder Auto PRO-YD-MBW21103-HID-DRL-BK Black LED Projection Headlight $413/ea
so far they've been rock solid on his car - anyone else have experience with Spyder products?
#104
yes, he's been really happy with them, he loves the look and says he can see better than his old OEM setup - some of it probably depends on the bulbs/kelvin you use as well..
#105
03 E55 AMG
Well I threw a S/C belt today and I have the smaller eurocharged pulley. Would the gates tight fit belt be ideal? I was just wondering if the extra pressure would cause more stress on the S/C bearing. Any opinions.
#106
#108
Can anyone give some feedback on the quality and reliability of Dorman Control arms? I just purchased them for each side and by the looks of them I'm not to keen on putting them on the vehicle. Any feedback is greatly appreciated.
#109
some other low-dust pads
Wagner ThermoQuiet MX1231 Semi-Metallic Disc Pad Set, Front $45
Wagner ThermoQuiet MX984 Semi-Metallic Disc Pad Set, Rear $44
i haven't heard anything bad
#112
#116
How about this one?
URO Parts 112 200 0970 Belt Tensioner : Amazon.com : Automotive
#118
as LED technology improves, here's a new design that has 2,000 lumens - great for fog lights (depending on if you're color matching, etc)
these H7s will fit the E63 foglight setup
LED Headlight features:
Plug & play, No need to cut and wires.
Low Power Consumption, Long lasting.
200% brighter than your stock Halogen headlights.
Low Voltage Protection, High precision Constant Current Driver Chip.
Built in IC Circuit (Current Regulator)-Prevents LED Damage From Voltage Variations & Spikes.
Up to 30,000 Hours Service Life.
Specifications:
Power: 50W/set
Voltage: DC12V-24V
Material: Aluminum
Color temperature: 5000K
Beam Angle: 360 degree
Size: Approx 19.6mm in diameter and 93.2 mm in height
Input: 2.2A ± 0.1A
Lumens: High beam1800lm/bulb
LED quantity: 2PCS Cree-1512 chips each
Certifications: CE, RoHS
Package included:
2 - Cree LED bulbs
2 - Micro-fans
2 - Ballasts
New Brights LED Headlight Conversion Kit - All Bulb Sizes - 50W 3600LM Cree LED - Replaces Halogen & HID Bulbs - H7 $99
E55 bulb size (9006)
50W CREE LED Head Light Head lamp KIT H4 H7 H8 H9 H119005 9006 Color 5000K $95
Specifications:
Power: 50W/set
Voltage: DC12V-24V
Material: Aluminum
Input: 2.2A ± 0.1A
Package included:
2 - Cree LED bulbs
2 - Micro-fans
2 - Ballasts
#122
E55 & E63 Front Wheel Bearings
Mercedes (00-09) Wheel Bearing Front Inner + Outer (2 pcs)) OEM w211 w215 w220 $96 shipped
Mercedes (00-09) Wheel Bearing Front Outer L=R (x1) GENUINE w211 w215 w220 #A230 330 03 25 $56 shipped
Mercedes (00-09) Wheel Bearing Front Inner L=R (x1) OEM w211 w215 w220 $48 shipped
#123
Oil
Mann-Filter HU 718/5 X Metal-Free Oil Filter $9.32 (free shipping with Prime)
Mobil Jet II Turbine Oil - Quart Can $16 for S/C oil change
AIR FILTERS
K&N 33-2181 High Performance Replacement Air Filter (need 2) $38.64/ea
IGNITION SYSTEM
1 step colder NGK (2309) LFR7AIX Spark Plug - Pack of 4 $33.80/4
AIR FILTERS
IGNITION SYSTEM
#124
BMW M5 + E55 AMG
How often are you guys changing the supercharge oil? I was told it is "lifetime" fluid. My car is bone stock, so it doesn't see any excess wear on the S/C motor but I am at 130K miles..
