Oil all over drivers side of motor... fml
Old 09-26-2013, 07:57 PM
S2K750's Avatar
Daily 06 E55, Fun 12 GSXR750, Racing John Deere D110
Up until today the motor has always been spotless. Not a hint of oil anywhere.. I just took the car out for a spirited drive and within a mile from the house I noticed smoke coming hardcore out of the exhaust. No lose of power, hesitation or anything funky.
I pulled over as soon as I noticed and checked the oil level. The car said add a quart to get to full. I had it filled to 7.5 and its now at 6.7.
Normally I'd assume a valve cover leak, but thats typically something that goes bad over time. I've never seen it spray everywhere like the pictures below and smoke out of the exhaust?
Ideas?
Old 09-26-2013, 08:23 PM
S2K750's Avatar
I cleaned it up and out the factory airbox on.. The smoke out the exhaust came from sucking up the oil via intake. Drove 2 miles grandma style and no oil spill. I hit boost for 1500 rpms and there's oil everywhere again.
My best guess right now looks like the filler tube or valve cover. The oil filter housing is solid from what I can see
Old 09-26-2013, 09:02 PM
E55AMGGG04's Avatar
04 w211 E55
Oh wow I just saw this now. Looks like the same problem :/
Old 09-26-2013, 09:06 PM
E55AMGGG04's Avatar
04 w211 E55
I felt like it's the valve cover also. I can move the whole thing and I feel that it shouldn't be able to move at all. After the cleanup though it didn't look like it was coming out from there so I was confused.
Old 09-26-2013, 09:11 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Do a compression test ASAP
Old 09-26-2013, 10:00 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
You...can...move...your...valve...cover?!
Old 09-26-2013, 10:09 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
Back in my college days, my modded talon tsi would blow the dipstick out and coat the engine with oil under heavy boost. The worn piston rings were no longer able to manage the pressure of high boost.......
Old 09-26-2013, 11:05 PM
GunMoto's Avatar
EG8 | E46 | W211
Posted this in the other oil spray thread:
Originally Posted by GunMoto
If oil is coming from the filler neck, check the gasket for the cap. Furthermore, there is an identical gasket also sealing the filler neck to the valve cover. The filler neck is twisted onto the valve cover and locks into place. You will need to lift the base of the filler neck (it is spring loaded) over the protruding tooth on the valve cover and twist to remove it--check that gasket.
If you can move the valve cover, then your valve cover bolts are loose! I suppose it's possible for some bolts to loosen over time? I recently replaced my valve cover gaskets and like 2 bolts seemed pretty loose. Adding to that, if your valve cover gaskets are shot, then no amount of tightening the valve cover bolts will help because although the rubber gasket is sandwiched between the cover and head, the actual cover mounts directly to the head's surface.
There's no oil pressure under the valve cover, but there are definitely oil sloshing around when the motor is running with oil squirters, and such.
Old 09-26-2013, 11:26 PM
E55AMGGG04's Avatar
04 w211 E55
^ I'm going to the dealer tom to get parts. If I get it switched it and down before you I'll let u know if this worked.
Old 09-27-2013, 12:06 AM
cij911's Avatar
one car at a time
By any chance did you cap off the breather lines ? It sounds like you are building up excessive pressure, which should vent from the 3 valve cover vents (unless some butthead plugged them up...)....Ideally the lines will vent to a oil separator and then back to the intake (vacuum)....
Old 09-27-2013, 01:35 AM
Goni C63's Avatar
C63/X5/ML/YUGO
Hey man sorry to hear that you have this kind of issue with the car but if you going to bring the car there and drop it off for repair you know my bro is the auto mechanic and he will save you big chunk of the $$$ specialy on there hourly labor $ and plus god knows what they ganna lie and you know any car that gets in my bros garage turned out to be faster lol any help you nead please do not hesitate to call and specialy that you drive AMG!!!
Old 09-27-2013, 10:49 AM
E55AMGGG04's Avatar
04 w211 E55
You got it man! Im going to get a new filler neck and cap with gaskets and check all the lines and hoses today and I'll let u know
Old 09-27-2013, 10:53 AM
Joncl's Avatar
E55
Oil shooting out the motor is never good, please do a compression test as well
Old 09-27-2013, 12:15 PM
E55AMGGG04's Avatar
04 w211 E55
The valve cover comes in 1 piece with the filler neck and new gaskets. Parts at Benz wants $400 negotiable so probably can get it for less than that. They said you can't get just filler neck and gaskets. I want to get this but I still havn't actually seem it come out. I'm going to do some more checking today and see if I can actually see the oil come out from where its leaking before I order this part.
Old 09-27-2013, 12:49 PM
shardul's Avatar
keep us posted on what you find
Old 09-27-2013, 01:22 PM
E55AMGGG04's Avatar
04 w211 E55
Will do! I'm going to tie a rag around the filler neck and take the car around the block and I'll accelerate enough to have some oil come out. The car Can be driven and there is no sign of leaks when the car is running. It's hard acceleration that gets it to come out. If that rag gets soaked and everything else looks dry I will order this piece and hope to call it a day!
Old 09-27-2013, 05:44 PM
E55AMGGG04's Avatar
04 w211 E55
I did a little ghetto test. I tied 1 rag around the oil filter and 1 rag around the oil filler. It ended up shooting out through the oil filter!!' Check your oil filter bro. The rag was drenched in oil. A gasket must've went bad on the oil filter. I also found a EVAP house disconnected which triggered a cel a few weeks ago. It happened to be the same one but on the other side.
I can't believe it. Almost too good to be true. Try doing the same thing bro I'm almost certain the same thing will happen for you!
Old 09-27-2013, 07:04 PM
S2K750's Avatar
Haven't had a chance to test compression to check for damage from the lack of oil pressure. I believe I found the source though. If you look by the oil filter directly in front you'll see two feed lines; I think the bottom oil line is leaking. Tonight I'm going to wrap everything individually and test to be 100%.
I'll post up compression numbers and my findings tonight.
To answer the posts above. Only modification to the car are intakes, cuts outs, split cooling, and h/e. Nothing capped off or modified. I don't see where the vents are on the valve cover; all the oil is in the front if that helps. I'm feeling much more optimistic today, probably won't cry myself to sleep again.
Old 09-27-2013, 07:29 PM
Forrest Gump 9's Avatar
shrimp boat
It's your oil filter housing. The rubber gasket get pinch and under pressure the oil would spit out.
Old 09-27-2013, 07:31 PM
E55AMGGG04's Avatar
04 w211 E55
This is what is happening to me.
Old 09-27-2013, 08:36 PM
S2K750's Avatar
Soo... This is going to be the most ridiculous post I ever write.. Ignore the grammar, on a cell.
We wrapped each item one by one with a towel and zip tie. Then we went for a drive and figured out it was the lower oil feed line. We wanted to confirm that was it by doing a burn out with the hood up and everything wrapped except the leaking hose. So as soon as I hit the gas oil came out of the hose and the motor literally lifted 5-6". I knew I needed motor mounts but I didn't know it was torn in half.
After finding the issue we tested compression on the two problematic cylinders 1 & 8. Cylinder one tested 163. Cylinder 8 164. Both tested 3x each. Spark plugs all looked great for 90k.
I'll be changing the plugs out soon and will test all the cylinders.
Conclusion... Broken motor mount stretched the feed line which caused a leak.
Now time to celebrate!
Old 09-27-2013, 08:47 PM
Joncl's Avatar
E55
Maybe I missed it but did you get a cel?
Old 09-27-2013, 08:53 PM
MAN55LE's Avatar
04 E55 AMG
Great job diagnosing it , and thanks coming back and letting us know... hate when we never find out the actual problem/fix.
Old 09-27-2013, 08:56 PM
S2K750's Avatar
No cel.
You guys have been very helpful now and reading the last 10 years of posts. I hope my thread will help others in future.
Old 09-27-2013, 10:15 PM
shardul's Avatar
very nice!!!
Quick Reply: Oil all over drivers side of motor... fml
