P200A code?
Old 11-18-2013, 03:43 PM
chawkins2001's Avatar
2006 E55 AMG
P200A code?
Anyone know what this code is, and figure out what the cause and fix is:
Old 11-18-2013, 03:50 PM
E55Greasemonkey's Avatar
Received 1,483 Likes on 983 Posts
This place is a joke.
First check the trans control unit for trans fluid intrusion, if there is none,we typically clear that code and if the car shifts fine we send it on it's way. If it does not shift fine then likely the trans control unit has failed internally.
Old 11-18-2013, 03:53 PM
2006 E55 AMG
I got the code at the track and checked the TCU for fluid and looked at the board. No fluid and the board look fine so I cleared the code. The car would fall on its face giving it any sort of medium to heavy throttle after the code was cleared.
I have never seen a EGS fail, have any of you fellas?
Old 11-18-2013, 04:00 PM
I have seen them fail. It's not very common, but neither are the mods on your car
Did you try clearing the fault and resetting the shift adaptations at the same time?
Old 11-18-2013, 04:08 PM
2006 E55 AMG
I sure did bro I do have a spare TCU I will try out and see if that one works.
Old 11-18-2013, 04:42 PM
That code can also show up if the ecu and valve body are not compatible parts. Did you put a different trans in the car?
Old 11-18-2013, 04:47 PM
Denroll's Avatar
'06 E55
Oh hey, look... it's a code I haven't had.
And here I thought I had collected 'em all.
CooperK (04-11-2023)
Old 11-19-2013, 05:57 AM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
I have seen this fault numerous times. The majority of the time there are no side effects whatsoever. If you have cleared it , and it returns. You have an internal processing failure of the EGS control unit.
Old 11-19-2013, 08:43 AM
2006 E55 AMG
After checking my notes on my build, I have figured out what the code came from. If get a TCU tune from a vendor, and choose to do it with a different EGS other than the one that originally came with your car, this code will remain stored if you don't VIN code the new EGS.
Old 11-19-2013, 09:05 AM
99lightning's Avatar
99 ford lightning
so i shouldnt get that code since i sent my original tcu out
Old 11-19-2013, 09:13 AM
2006 E55 AMG
You are correct brotha.
Old 12-30-2013, 11:49 PM
Mulletmudbogger's Avatar
Bus Honda accord bus
Any updates?
My e55 is throwing the same code. Not sure how long it's been throwing it because I just got das.
My Tcu connector was wet and my board had a small spot of fluid inside.
I cleaned everything replaced the leaking trans connector and I'm still getting this code.
I think my Tcu is fried and the transmission shop will not look at my noisy transmission until I get that code cleared so I've ordered a new Tcu.
Old 12-31-2013, 10:14 PM
Here what you don't want to see on your Tcu connection behind the passenger floor carpet.
Old 08-26-2019, 10:14 AM
C55er's Avatar
C55 AMG
I know this is an old thread, but I'm going to try my luck anyway. How would you VIN code the TCU? Thanks in advance.
Quick Reply: P200A code?
