Can you manually change gear in S mode in the E55?
Old 08-29-2014, 04:51 AM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Might be a stupid question. On the CLK55 you have to select manual mode to be able to use the gear switches on the steering wheel.
The E63 I drove you can change up/down a gear which ever mode you are in and it will go back to auto again if you hold the right paddle or leave it for a while.
Does the E55 work like this? Or can it be adjusted/tuned to work like this. I know that if you put a 05/06 CLK55 TCU into a 03/04 it magically gains this ability.
Old 08-29-2014, 04:55 AM
MAN55LE's Avatar
04 E55 AMG
When I hit the paddles on the steering wheel, I can manually go to that gear in any mode....
Old 08-29-2014, 05:08 AM
RAWE55's Avatar
C63 AMG, E55 AMG
^^^ what he said, you can change gears in any mode with E55. Can be a pain in the *** when you accidently hit the shifter on the steering wheel making a turn at speed and it down gears into a lower gear. Done this before.. Plant your foot and pretend like you know what your doing leaving sideways and smoking up the street. Less embarassing
Old 08-29-2014, 09:18 AM
E55Freak's Avatar
2005 E55 silver
or you can just hit the right paddle until it goes back to "D."
Old 08-29-2014, 10:00 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
As everyone else has said, you can downshift with no problem. The problem is upshifting in S mode. If the car determines that the amount of gas you are giving it means that it thinks you should hold the gear longer, then it can ignore your upshift input and it will upshift when it thinks you need to.
Old 08-29-2014, 05:02 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
'03's can only use the paddles in M mode. '04 and up can use the paddles in S and M.
Old 08-29-2014, 06:13 PM
tw2
tw2's Avatar
Thanks everyone, this definitely answers my question. Definitely looking at an 04 then. It is very annoying having to go S to C to M then 4th to 3rd to 2nd for my favorite corner or roundabout and then back to S again.
Driving in M mode everywhere gets a bit tiring and kind of makes it pointless having an auto but on the other hand the TCU does not know what a roundabout is.
Old 08-29-2014, 06:39 PM
chiromikey's Avatar
Keep in mind that you can still downshift in S mode using the gear shift lever, just not the paddles. I wouldn't let that stop me from buying a good '03 if I found one.
Old 08-29-2014, 07:12 PM
tw2
tw2's Avatar
That is true but if it is like the CLK then you hit it left and it goes to 4th initially regardless of what gear you might have been in before. I do find it helpful in manual mode going around sharp corners when you have no idea where the steering wheel button is.
Old 08-29-2014, 07:28 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Correct
Old 08-30-2014, 08:37 PM
Whats_AMG's Avatar
e55
I can change gears from paddles or shifter in any mode C,M or S in my 2004.
Old 08-31-2014, 01:11 AM
Can Drive 55's Avatar
2005 E55
Ditto on my 05.
Old 08-31-2014, 01:44 AM
tw2
tw2's Avatar
Just out of interest I am guessing there is no way of adding this ability to the 03's?
Old 08-31-2014, 07:04 AM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Im interested aswell.. maybe through a update/Tune of the TCU?
Old 05-30-2017, 02:02 AM
ben73's Avatar
W108 3.5 - 2005 E55
Thread dig
I have an 05 and as chiromikey wrote above, you can knock it down a gear with the buttons or the shifter while in C, S or M.
Is there anything I change in STAR to make it like an 03 so the buttons and sideways movement of the shifter only work in M mode?
THANKS.
Old 05-30-2017, 02:45 AM
tw2
tw2's Avatar
I forgot about this thread. It is definitely helpful. I just wish it let you upshift to a higher gear as well as a lower gear. Sometime the TCU feels like you have to get to 3000rpm despite very light acceleration.
Quick Reply: Can you manually change gear in S mode in the E55?
