meth kit for e55
meth kit for e55
hi all.
finally decided to go ***** in with the mods on my ride. will start building headers soon. in the meanwhile, i would like to order a meth kit.
which one would you advise?
please link me whatever you think is the best kit.
I am seriously considering meth as well especially with a fixed solid pulley going on the car soon. I guess I do not really need anything special just one that will work under wot and certain boost levels.
How much of a pain is it to install? IE wiring it to the car?
Im getting ready to pull the trigger too. Which meth kit though? There are several, one that runs off boost, manifold pressure, and MAF sensor....not sure which one is best to work with?
From what I understand bip nor EC will tune for meth, in other words they will not add timing to take advantage of the extra octane, they will use for cooling though
I know EC doesn't but Jason said they will if that's what I want, so I guess we will see once I make the switch. I hope they do i thought I read somewhere Craig was tuned for it on his previous setup maybe he can chime in.
No craig was not tuned for it, he used it for cooling. Unless you have failsafes within the tune and meth system then tuning for it can lead to catastrophic failure it something goes wrong
You really won't gain a lot of HP from adding more timing....the big benefit will be cooling and the ability to run more boost (over just pump gas). Just make sure you have great failsafes....
Any shops sell these meth kits like the aquamist? Seems EC does not and will not install (called last week, said he will check if they do, no more responses)
If you are in the US, then howerington engineering is the only one, unless there are resellers
Installation should not be hard, as for tuning, EC will not tune for the extra octane(adding timing etc) but can be used for cooling. You can use a smaller nozzle and add less meth to the mix so it will not affect the afr so much
