E55 supercharger air flow increase
Old 12-21-2014, 02:25 PM
demetaktak's Avatar
04 E55 w211
hi. yesterday i removed the supercharger to fit 82mm TB. and while at it, i couldnt help it to notice these "air restrictions" in it when i took it appart. logically i think they are to limit flow and increase boost. is there any other reason for those in the right bottom and above corner of the rectangular hole?
i am thinking of removing them, neatly to increase flow and increasing crank pulley size to compensate. what do you think? has it been done before. also i was thinking to increase the size of the hole by shaving 0.5cm. and polishing it.
and what about the sc oil, should i change it? i smells nasty in the boot of the other car
waiting for your chimes before i go on...
Old 12-21-2014, 02:56 PM
99lightning's Avatar
99 ford lightning
outlet
here is a outlet on a whipple twin screw, the outlets on the 55 blower do look goofy think it prob has to do with the placement of the rotor pack
Old 12-21-2014, 05:49 PM
sexyxe's Avatar
04 E55
This is thinking out loud, but those extra pieces may be to help direct airflow down the guts, prevent extra turbulence, help with resonance or limit air sliding down the sides.
Pure speculation. Id hate to see you modify it and make it worse. Would be great to see an improvement though
Old 12-21-2014, 06:09 PM
1970gsx's Avatar
'06 E55
Most likely correct. Attched is a pic of a power plate that we use on the turbo Buicks to even out air distribution at the plenum, where Buick just had it wide open. Dyno and airflow test proves it works. Looks like MB figured it out.
Old 12-21-2014, 08:40 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Here is a fully ported blower, done by
http://stiegemeier.com/services/supercharger-porting/
Old 12-21-2014, 10:49 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
It didn't make a difference right ?
Old 12-22-2014, 12:26 AM
demetaktak's Avatar
04 E55 w211
yacht master, well, this was helpful and dilema-ending i will just take care of the TB then, leave the outlet alone..
thanks. and what about the sc oil? should i change it?
Old 12-22-2014, 12:58 AM
thumper823's Avatar
04 E55
Yes I would since you have it removed already. Mobil jet oil
Old 12-22-2014, 05:23 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Those notches in the diagonal sections of aluminum are there to silence the blower noise. If you weld them up the factory blower will sound just like a whipple.
Old 12-22-2014, 09:07 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Beat me. You've been on top of things lately bud
Old 12-22-2014, 09:08 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Cleaning up the TB inlet and porting the SC to air tank ports helps flow as well. Just in case taking apart the sc is more than you would like to tackle.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 12-22-2014, 09:31 AM
03svtkiller's Avatar
2011 Cadillac CTS-V
I have my blower ported by stegi, the link yacht-master posted is actually my blower lol he has several pictures of it on his rebuild album i didnt do before after dyno for it, but there is a difference more air flow runs more efficient.
Old 12-22-2014, 10:34 AM
Might be fun to do, what you think? Weld up the silencers and install a fixed pulley on the supercharger for beautiful engine music
Old 12-22-2014, 11:51 AM
Luxury4play's Avatar
E55
what notches in the diagonal section? you talking about the corners of the opening?
Old 01-03-2015, 09:35 PM
SICAMG's Avatar
2005 e55 AMG
I guess you would weld each hole on the right and left side tabs. For the life of me I don't know why it would get louder......but I would do it I think!!!!
Quick Reply: E55 supercharger air flow increase
