Red dust around supercharger pulley
Old 01-25-2015, 03:59 AM
Mr. CVE's Avatar
MY06 E55
I did a search and found nothing, maybe I used the wrong search terms ?
Anyway, I have some red dust around the blower pulley.
I replaced the bearings in the belt wrap kit as they had slop in them, turns out pulley bearing bore is larger than bearing od, so will never fit properly
But changed them and belt, and I am just seeing a bit of dust.
I remember seeing this kind of dust on the crank trigger ( dizzy ) on a nissan RB30 motor.I think the bearing fails.
Is this the case here ?
It is an aftermarket clutched pulley if that helps.
When I start the car cold, it does squeak a little.
Any suggestions ??
Thanks in advance.
Old 01-25-2015, 09:44 AM
berti_00's Avatar
2016 Cls63s AMG
That's from the pulley when it engages the friction crates that dust
Old 01-25-2015, 11:59 AM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Correct. The friction surface is carbon and when carbon oxidizes it creates rust. This is why the dust appears red
Old 01-25-2015, 01:18 PM
kponti's Avatar
E63
You might be too shimmed out
Old 01-25-2015, 01:43 PM
Love amg's Avatar
03 e55
It's your supercharger pulley going bad mine is the same I am changing the bearing in it because the pulley was installed wrong .
Old 01-25-2015, 04:54 PM
Mr. CVE's Avatar
MY06 E55
Thanks, the bearing felt fine when the belt was off.
If it is just normal wear I am okay with that, as the car does get driven, and the clutch is probably under a bit of extra load ! ( 178 lower pulley 84 top ).
It is not a lot, but just something I did notice.
I would rather not mess with it ( if I can avoid it ) as I hear so many bad stories about pullies on these things.
Old 01-25-2015, 06:03 PM
Love amg's Avatar
03 e55
Yea it's so many pullies I got a 180 mm pulley and the supercharger pulley went out and we just slapped it on the blower just like that but you gotta measure it and suppose to fit a credit card between the clutch and the pulley. So it was done wrong so the mechanic told me we gotta do it again thats where the red color is coming from.
Old 01-28-2015, 01:05 AM
NafisC's Avatar
W211 E55 AMG
You will need to address the space between the pulley. I'm facing the same problem and if you wait too long to fix it the clutch will fail to engage or disengage
Quick Reply: Red dust around supercharger pulley
