Need Help Facelift mirror + aftermarket caps
hi guys .. I can installed the facelift mirror no problem. the thing is that I got aftermarket 2 led + courtesy light mirror caps which has a white color led located underneath the cap. do I have to tap it into the footwall light? that require to take off door panels ...is there a easier way to wire this light up? thank you for your help.
Yes it can be done but you have to drill new mounting holes. Also you can wire the courtesy light to the courtesy/puddle light on the bottom of the door.
