US service 9; Check preload pressure of reservoir
2006 E55 AMG
I'm assuming this is something that can be read in DAS. what is the procedure, and what is spec for this preload pressure?
Thanks.
Thanks.
2006 E55 AMG
I didn't find (look for) a self test, but the actual values can be read here:
Control Units > Chassis > SBC > actual values > pressures>
Some good info here: http://bayhas.com/mercedes/w211/contents/INDEX.htm
Mine measured 95 bar on a 2006, so I'm guessing it was recently replaced by the previous owner. Yay!
You will have to go in to: (complete list of guided tests) to find the pretension test. The pressure reservoirs do not fail that often. You may have a fault for it but it will pass the test. This will require replacement of the SBC unit as a whole.
the pressure reservoir can be replaced separately.
