Troubleshooting dim headlights
picked up an '06 E55. Maryland inspection said lumens weren't high enough and I did notice that the headlights aren't very powerful. Installed a pair of new bulbs yesterday. No change. I know the W210 chassis had harness problems but I don't see anything on this car. Any ideas how to t-shoot this?
I can check but rest of car electronics are solid. Blinkers fine. Where does that pigtail to the power pack ground? I think it's 3 active pins and I would assume that one is ground but carries back via harness to some central location.
07 E63 + 07 CLK63CAB
Grounds are usually solid black in colour, check the connector for corrosion first.
Verify the ground wire with a meter.
Then I would tap into the ground wire and find a nice chassis ground place to check to see if that improves the lighting.
Is the high beam also affected?
