Keyless Go T-Shoot
Keyless Go T-Shoot
I recently picked up an '06 E55. It has the keyless Go and it works to start the car, but the outside unlocking does not work. The previous owner said something about the Fobs not being the right ones but he also didn't know. Does anyone know if there is more than one FOB or is it simply a programming issue?
Any helpful advice appreciated.
He is asking whether any of the doors lock/unlock by touching? if so, then the sensor on the door handle has gone bad and needs replacing. this is a common issue with these cars and is an easy fix.
https://mbworld.org/forums/w211-amg/...ement-diy.html
Also suggest checking the Key Fob batteries. They might need replacing if they've never been replaced before; mine was low and I just replaced recently (2006, 54K miles, second owner).
ok. yes. check each door handle and see if they work. There is no universal wire that will make them all work. My car has one rear that will lock/unlock the car and my passenger door will only unlock. I am not worried about replacing them since they go out so frequently...but that is me.
Interesting. The only button that I found works is the RR passenger door for unlock. None of the others work. Is it a contact issue that might be fixed with electrical contact cleaner? How hard to replace? If I did, I would only do the drivers door. Going to pick up batteries also as I just started getting the key fob battery low message on the dash today.
Received 1,467 Likes
