My fuel tank recall alternative :)
Old 05-05-2015, 01:46 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
So I, too, experienced a gas smell and small puddling in the passenger side fuel hat. Since I'm running a pretty heavy fuel system (twin 340LPH pumps, ID1000 injectors) to support higher than average power, I also experienced something additional... melting of the bulkhead connector within the fuel hat.
My fuel tank recall alternative :)-imag0557_zpsyokdmahe.jpg
My fuel tank recall alternative :)-imag0560_zpsc1n0lncd.jpg
I've seen pictures recently where Denroll also showed signs of this failure. This is alarming to say the least... it shows the factory system is clearly not up to the task with respect to any pump amperage higher than stock. I wonder how many stock pump modded guys are starting to experience the same. I didn't want to throw another stock assembly in there and wait for a re-occurrence so I took a different approach.
My fuel tank recall alternative :)-2015040295142135_zps7di2zulg.jpg
My fuel tank recall alternative :)-imag1442_zps9gckfr8c.jpg
My fuel tank recall alternative :)-imag1435_zpswwuion7a.jpg
My fuel tank recall alternative :)-imag1436_zps5xpz53an.jpg
My fuel tank recall alternative :)-imag1439_zpsuomz0lqo.jpg
My fuel tank recall alternative :)-imag1443_zps1ejgfyms.jpg
The new bulkhead connector is rated for 40 amps, over double what the stock terminals are rated for according to my calculations. No leaks... ever. Fits like stock, tighter tolerances on everything obviously with the billet aluminum structure. I've been running it for a week so far with no problems and harness temperature is reduced (subjective, by touch).
Just showing off. Anyone can think outside of the box, just put the pen to paper and get the ball rolling on your own projects.
Old 05-05-2015, 01:55 PM
Hulk's Avatar
A Merc
Clean
Old 05-05-2015, 02:06 PM
Denroll's Avatar
'06 E55
Looks awesome! And WOW at your melted plug. It looked a lot worse than mine. Scary to think about that being located where it is.
I just caved in yesterday and ordered a new fuel pump and sender unit for the right side. If I have another issue, I might try a Google scavenger hunt on the numbers on that 40A connector.
Old 05-05-2015, 02:11 PM
If you end up having another issue, shoot me a message and we can work on getting you fixed up
Old 05-05-2015, 02:21 PM
SilverStrk's Avatar
05 E55, 07 ML500
OUTSTANDING You should show this to MB engineers.. That connector is Scary
Old 05-05-2015, 03:09 PM
Hulk's Avatar
A Merc
It's not really the connector, it's the issue that the filter gets dirty and starts to make the pumps work harder, needing more power until it fails. The real alternative would be to reengineer a fuel filter system without it being attached to the fuel pumps, so you can change out the filter every 40-60k miles.
Old 05-05-2015, 04:47 PM
I replaced my fuel filter with a brand new aftermarket unit before my over current condition on the fuel pump hat materialized. Additionally, the 340LPH pumps require a whole lot less load for the same flow so even a dirty filter isn't working them as hard as the stockers are working.
Old 05-05-2015, 04:50 PM
Hulk's Avatar
A Merc
For some reason the aftermarket filters that are inline are still making the pumps work harder. It's just a bad design. The SL55 are much easier design and don't have the same issues
Old 05-05-2015, 07:04 PM
jcjmw's Avatar
2005 E55 Wagon
mmm...can you put the oem sl55 pumps inside the e55 tank?
Old 05-05-2015, 08:10 PM
Hulk's Avatar
A Merc
Nope, different design
Old 05-05-2015, 09:00 PM
Denroll's Avatar
'06 E55
What would have to be changed? Already sounding like a "more trouble than it's worth" project, but it would be cool.
Old 05-05-2015, 09:15 PM
Hulk's Avatar
A Merc
Everything the pumps wouldn't fit in there, the gas tank would not work with those sl55 pumps
Old 05-05-2015, 11:08 PM
BC928's Avatar
E55 and several 928s
Denroll - It seems to be related to Racetronix, etc.
http://ls1tech.com/forums/attachment...connector1.jpg
Above looks familiar, doesn't it? I suppose I could be wrong, but why we have to guess, I have no idea. Love the guessing games we have to play on this board.
Old 05-06-2015, 01:08 AM
austingtir's Avatar
04 E55 AMG, 06 CLS63 AMG 14 E350 14 S550
Your the man bro. Iv been thinking about doing exactly this for my own car as I hate the way that fuel can wick up through that plug!!
Old 05-06-2015, 01:13 AM
das eighty's Avatar
'04 E55 AMG
Holy crap. Well done.
Old 05-06-2015, 05:28 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
Nice piece of work! Can't wait to see what you come up with when the other side goes brittle.
Old 05-06-2015, 07:49 AM
I did not replace it with an inline aftermarket filter. Even if I did, those inline filters support power much greater than anything an M113 has produced so that would not be the bottleneck in our system.
Old 05-06-2015, 08:17 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Rockthemullet, that is some pretty work there, are you going to do a limited production?
Old 05-06-2015, 09:18 AM
chawkins2001's Avatar
2006 E55 AMG
Very nice work Eric Looks like a Fore piece!
Old 05-06-2015, 12:50 PM
blackbenzz's Avatar
haters crazy
Awesome work How many times does your traction control light blink per second now?
Old 05-06-2015, 03:00 PM
SICAMG's Avatar
2005 e55 AMG
I cant see that being the case. The billet inline I have flows some silly amount...don't remember the flow numbers, but with the factory filter removed and the modified fuel line from the tank and rail its got to be better I would think. My concern was the actual filtering due to the crazy flow rate. Could be wrong but I would rather have it set up this way.
Old 05-06-2015, 03:58 PM
After some more testing I could do a small group buy here. The design is proprietary to my machinist so I can't hand that out to anyone and I would need to find a better supplier for the bulkhead and connectors. If there's enough interest, I'd have no problem putting the time in to get these out to others
I could anodize it black and etch the name in the top, haha
About tree fiddy
Old 05-06-2015, 05:54 PM
Max.H's Avatar
E55
Nice work
Old 05-09-2015, 05:04 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
Wow. That looks great.
Quick Reply: My fuel tank recall alternative :)
