Codes P20A2 and P202B-2 step in
Old 05-21-2015, 11:00 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
P20A2 idle speed control implausible:
Check system for unmetered air
P202B-2idle speed control implausible
Short circuit to ground or open circuit
No obvious vacuum leaks,this is an 06 E55 175 lower pulley,PLM headers,EC tune,no cats ,stock TB and air intake set up, car runs perfect, was thinking maybe tune issue.
Old 05-22-2015, 05:38 AM
menace2sobriety's Avatar
2004 E55 AMG
I have seen these codes before
Read my thread here to see if it helps or if your symptoms are the same
https://mbworld.org/forums/w211-amg/...dvice-e55.html
Out of Curiosity - Do you have the bonnet lining/bonnet vent underlining removed do you?
After some random MAP sensor errors (hidden until logged in SDS) I got a LOT of P202b-002 Idle Speed Control Implausible - Short circuit to ground or open circuit
P20A2 - Idle speed control Implausible
P202b-002 comes up every time even after clearing the codes
Swapped my "STOCK" throttle body out and it was all fixed.....no more errors no more drive-ability issues
Quick Reply: Codes P20A2 and P202B-2 step in
