High Pitch Whining 06 E55
06 E55 AMG
This noise is driving me bat sh*t crazy! I can't for the life of me pinpoint what it is I'm about to remove the supercharger to get a better look. Noise is originating from back of engine or supercharger area. Only does it with throttle closed (Second I touch gas peddle it goes away)
Please any help is appreciated, see video below!
Pull the S/C belt and see if the sound continues. It sounds like a vacuum leak. Our Lemons race car had the same sound...never figured it out...
06 E55 AMG
It's not the supercharger forgot to mention it only does it off throttle (Idle or cruising) second I touch the gas peddle it goes away.
I had a similar noise ,turned out to be the hole in the TB where the vent hoses attached,I had that hole plugged temporarily after I did 82mm TB swap and after I hooked up T fitting for vent hoses the high pich noise went away.
06 E55 AMG
Thanks!
