DEPO E63 AMG style headlights
Does anyone have any experience with DEPO headlights for the W211? They sell cheap on eBay and they're the facelift look. The question is, are they any good and also, do they look exactly like the OEM Hellas?
Pretty much, I replace my bi-xenons with the depo ones because they were fogging up pretty badly.
Looks good and better light output than my old ones that were all hazed up.
The slated turn signals gives it a updated look.
The shop installed it for me while they are working on the e63 bumpers said it was a direct plug and play, perfect fitment.
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
https://mbworld.org/forums/w211-amg/...eadlights.html
Knew I had read this but it was 3 years ago. Thanks SEARCH button.
Im debating whether to buy the DEPO's too however it says they dont work with Adaptive Headlights. Im okay with the adaptive not working, but it says they actually have completely different plugs so the entire headlight may not work.
1 - The new outside clear housing lens will bake open and swap from facelift Eagle Eye or DEPO housing to prefacelift OEM housing
2 - The complete facelift chrome plastic shrouds and turn signal, etc can be swapped from facelift Eagle Eye or DEPO housing to prefacelift OEM housing.
2 - The OEM Bi-xenon projector lens can be swapped to ZKW-R, Eagle Eye, or DEPO projector lens. (3" OD I think)
3 - The OEM Bi-Xenon projector can be swapped to EVOX-R Bi-xenon projectors.
If these 4 things are able to be swapped with little to no modification then this should be a no brainer for us guys looking to go facelift but keep all OEM features.
If someone could confirm that:
3 - I swapped my lenses out years ago to the ZKW-R
4 - I am unsure of.
'14 F15 M, '06 E55, '20 Highlander, '18 M550
Why not just have your OE lenses refinished ? Obviously not an option if you are looking for the E63 look, but otherwise they can be refinished to look new.
I will be doing a complete retrofit in the near future and I will try and take pictures / post a DIY for you guys.
If any body has some OEM headlights sitting around I would be happy to open them up and modify them to E63's with EVO XR projectors. See if the Depo internals will work. I am going to buy another set of the E63 Depo's for some custom work and may as well see what's what.
Edit: I should have the E63's by Friday. I'll take some detailed photo's of the inside. Here are the ones that I have from the last projector swap.
https://mbworld.org/forums/w211-amg/...ml#post6141646
My point is that even though you can polish and seal the lens, some sort of hazing will eventually come back. Please also keep in mind that some of us live in South Florida where our cars see sunlight almost daily.
Furthermore this is not the point of attention in this thread anyway lol.
Mine came in. Time to open them up and get to work
Using the high beam compartment as a intake hole, retrofitting projectors and custom lens and a few led bits in them as well.
Ah, good deal. The only reason I want to use the OEM base rather than the DEPO or other is simply because I dont want to lose the adaptive feature.
I look forward to seeing your results with this though. If at all possible, see if there would be any way to retrofit the adaptive housing & OEM ballast into the DEPO unit.
I'll take detailed pictures of the inside for you. The housings are cheap. I think they were $183 shipped. I'm fairly confident they will swap over. The internals have a lot of space for additional items
Thanks again.
Ha...well I just checked the housings. I thought I bought Depo's. I have Eagle Eyes LOL. I have Depo's on the car. I can compare both now. I'm using these to chop up and do experimental stuff with. Depo or Eagle Eye, they are getting cut up. Quality seemed decent for the 30 seconds I looked at them.
