wheel fitment
2005 E55 AMG
wheel fitment
I have an e55 2005 looking to get some rims I was wondering if anyone tried running 9.5in rims up front.
Ideal setup I'm looking at is 245/35/19 for 19x9.5 front & 275/30/19 for 19x9.5 rear
As for the offset I'm trying to figure out the lowest offset where the rim can just tuck under the fenders. Any help would be appreciated.
Looking at the forgestar cf10
I also happen to have 245/40 on another set of 18x9.5 rims and can tell you the tires are very stretched. 245/35 on 9.5 you would be even more so, plus you would have practically no sidewall for such a heavy load. Hope this helps
He would have more sidewall than those of us running 245/30_20s.
2005 E55 AMG
I run 18x9.5 ET35 with 275/35 up front. No rubbing or mods necessary and wheel clears the calipers with space to spare which means from a wheel/caliper perspective I could have gone ET36 or a couple mm's more. 275s may be the widest possible before the inner sidewall contacts the suspension or outer sidewall rubs the inner fender lining in a full lock turn.
2005 E55 AMG
