TBT, 55 Kompressor 7 years of porn
Old 07-30-2015, 10:42 AM
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
TBT, 55 Kompressor 7 years of ****
Almost 8 years of owning my 55 and posting up some Throwbacks, while clearing out the pic album.
Setting the 55 Texas mile record 5 years ago.
Stock manifold outlet size (circa 6 years ago) TBT, 55 Kompressor  7 years of porn-20131206_115902_zpsda03fbc4.jpg
600 plus RWHP dyno back 4 years ago or so.
Developing the aftermarket idlers for ours cars back about 7 years ago, after I had two stock sets fail on me.
Big valve ported head project back 4 plus years ago, after seeing how bad the stock valves and valve seating is on our aged engines.
Click image for larger version
AMG parties at the so called back woods dyno
Early race muffler set up.
Painted engine part days going abck 7 years.
My first blown engine back in 08 that I used to have the Darton sleeves developed for our M113K engines. Took over two years, donated block, tons of tech info and two SEMA mettings to convinve them but they finally did it.
Then came the Darton sleeved big bore blocks!
Belt wrap kit project
90mm throttle body project.
Could go on and on but this should be enough for a throw back Thursday reminiscing.
Attached Thumbnails TBT, 55 Kompressor  7 years of porn-stockandasppulley-1.jpg
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 07-30-2015, 11:25 AM
Denroll's Avatar
'06 E55
That's a lot of badassery for just one post.
Old 07-30-2015, 11:30 AM
Forrest Gump 9's Avatar
shrimp boat
Thank you for your contributions.
Old 07-30-2015, 02:06 PM
PLATINUM SPONSOR
2003 CL55
Any for your part numbers and wiring help on the BBK 90mm that ended up on Denrol`s car
__________________
www.ultimatepd.com
Old 07-30-2015, 03:40 PM
RedBullJnky's Avatar
you to Hate
Nice!!
Old 07-30-2015, 06:43 PM
moosejaw's Avatar
none
Agreed! nice
Old 07-30-2015, 07:44 PM
sircl55amg's Avatar
2006 cls 55 amg
more !!!
Old 07-30-2015, 08:00 PM
e500slr's Avatar
2011 E63, 2013 CLS63
600 + rwhp dyno, WOW!! How much exactly was it? I remember that video, it was after the ported heads wasn't it?
So was that 600 rwhp consistent and coolable? (if that's even a word )
Old 07-31-2015, 12:46 AM
JoeNobody's Avatar
Mercedes
Yes! More!
Old 07-31-2015, 11:21 AM
Super Moderator
BenzoBoi's Avatar
W221
OG status!
The 55K motor is one hell of a motor.
Quick Reply: TBT, 55 Kompressor 7 years of porn
