Hellcat Throttle Body?
Old 07-30-2015, 10:35 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I've been looking into doing a upgraded throttle body on my 55 engine while it's not in the car. Been going back and forth between the m273 throttle body and the mopar bbk 90mm. Then I got to thinking, what does the hellcat use? Well, it's a 92mm and they can be purchased new for less than $200. I assume the pin out and function is the same as the other hemi bbk brand throttle body that works on our cars. Any body know for sure if they electronically function the same?
Old 07-31-2015, 08:53 AM
kponti's Avatar
E63
If the pinout is the same I dont see why not? You will have to modify the crap out of the 82mm snout and adapter to fit that but I dont see why not
Old 07-31-2015, 04:14 PM
Denroll's Avatar
'06 E55
I like the way you think. Go ahead and give it a shot.
Factor in some money for a spare MB cable and the Mopar TB plug. If the TB doesn't work, at least you'll have the cable for the BBK and you can toss the Hellcat TB on ebay.
Old 07-31-2015, 06:27 PM
stockC43's Avatar
Exactly looking at the bbk's they say that they don't work for 13's on up. The bbk's work on our cars. The only issue (aside from tuning) I see is that mopar may of changed something electronic about the hemi tb's in 13. For $200, I figure it's worth a shot, but my car won't be up and running for a while though.
Old 07-31-2015, 09:02 PM
kponti's Avatar
E63
Just get the wiring done, plug it in and see if you can open and close with the pedal. Unplug and replug back to your stock tb and go driving.
Later after confirmation, you can build the necessary hardware to make it work
Old 07-31-2015, 10:02 PM
stockC43's Avatar
Not a bad idea My car is in pieces right now but I do have access to other 55's.
Old 07-31-2015, 10:48 PM
JoeNobody's Avatar
Mercedes
Not sure if pedal can be actuated before engine starts, but you could do the throttle body unplug reset, and that will actuate it. And then if no codes go build the snout
Old 07-31-2015, 11:19 PM
Manuyc's Avatar
06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
I'm definitly interested to see the outcome...
Old 08-01-2015, 08:34 AM
stockC43's Avatar
I would just use star diagnostic to actuate it.
I'm going to see what my dealer cost is on one next week and go from there. Looks like I'll be adding another project to my long list of projects.
Old 08-01-2015, 07:24 PM
Forrest Gump 9's Avatar
shrimp boat
I dont see why not. And yes, you can open and close the TB without the engine running.
Old 08-01-2015, 07:28 PM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
You could probably port out that 92mm to 95mm!!
Old 08-01-2015, 11:15 PM
shrimp boat
Haha, I want to know what's the hellcat upgraded to. That's the one I'm interest in.
Old 08-02-2015, 12:29 AM
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
Does anyone know if the hellcat bolt pattern is the same as the BBK? When I made my inlet for the 90mm I bored to 95mm just in case something bigger became available.
Old 08-02-2015, 09:33 AM
stockC43's Avatar
Lol. I'm sure a 100mm is in the works by someone. It's only a matter of time.
Scoto- I'll measure it out when it shows up.
Old 08-02-2015, 11:31 AM
Havoc's Avatar
Hell, I'm sure someone with the Weistec blower is trying a TB way larger than 100mm.. something like the Whipple "Big Bore" 170MM TB the Ford guys use.. or at least I'm wishing that so I can just bolt it on mine when I'm ready!!
Old 08-02-2015, 03:40 PM
JoeNobody's Avatar
Mercedes
170mm! Throttle body as big as your crank pulley, hah
Old 08-02-2015, 10:00 PM
Mike450's Avatar
2015 gl450
2013+ Hemi use a different dbw system vs the the sub 2012 models. They went to a brushless motor system within the throttle body. I'd guess it's going to pin out different.
IMO, skip the BBK and go with the Arrington 90mm. A few more dollars, but a better quality piece.
Old 08-03-2015, 11:33 AM
stockC43's Avatar
That's what I was afraid of. O well
Arrington huh. Not doubting you but what makes them better? Do the bbk's have issues? Last thing I want is to go through all of this and have a junk tb. That's why I liked the hellcat tb. It was oem. Thanks!
So, Arrington made a 100mm huh? Could be interesting
Old 08-03-2015, 09:01 PM
Max.H's Avatar
E55
That is what I'm talking about. Maybe 100mm??
The throttle body is a huge restriction in our cars. Terminator Cobras are supercharged V8 4.8L I think… Don't feel like searching. But, they use huge 100mm throttle bodies and make big numbers.
74mm is a joke.
Old 08-03-2015, 09:22 PM
stockC43's Avatar
Is this big enough?
Funny enough, tuning aside, it may actually work. If you can find a way to fit it, that is. It's for pre 13 hemi's using a kb blower.
http://www.kennebell.net/KBWebsite/A...ts/mam1880.htm
Old 08-05-2015, 12:44 AM
Havoc's Avatar
Originally Posted by stockC43
Is this big enough?
Old 08-05-2015, 07:40 AM
stockC43's Avatar
Unfortunately I gave in and am taking the easy way out, for now. I just scored a 273 (550) throttle body for $100 on eBay.
Old 08-05-2015, 11:49 AM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
It definitely works in regards to compatibility with the engine controls. My cars been down for
A while for body /paint mods so I can't get ya feedback on tuning just yet. Definitely overkill for the stock blower!
Old 08-05-2015, 11:52 AM
Hulk's Avatar
A Merc
Tuning wise it would be nice to see if it can idle normal lol
Old 08-05-2015, 12:00 PM
Havoc's Avatar
Quick Reply: Hellcat Throttle Body?
