Help with finding the right parts supplier for gas smell issue
Im trying to gather the parts needed to resolve the gas smell issue inside the car
Here is the list I made so far
Fuel pump assymbly 2114706494
Fuel sending unit 2114700000
Fuel sender seals x 2 2114710579
Fuel pump harness adaptor 2114400507
Electrical wiring harness 2115400700
Do you guys know any supplier of those parts other than ECSTUNING
Im trying to buy those parts asap,,thanks for your help
Sir, mbusa has settled the lawsuit and all dealers are obligated to change everything free of charge if there is a fuel smell inside cabin or if the is a leak in either gas tank, fuel pumps or senders
Received 1,483 Likes
This place is a joke.
You'll be needing the complete assembled gas tank (the 6.3 version not the 55)
The tanks leak from the top valve as well as the senders/pump.
Sorry I don't have the part number right now but I can get it.
Thank you all for your input,,got the parts finally and the beast is back to life.
No more gas smell and throttle response dramatically improved.
Them filters were so clogged that cause the gas pump to overheat and melted the plastic connector in top of it.
Update: after using the car for two days,,,gas smell issue is BACK AGAIN,,the brand new 600 dollars gas pump started leaking from the connector again,,well done Mercedes!!!
Just dropped to the shop today,,im gonna try a connector delete and wire it directly,,as far as plastic cover goes,,will use jb weld to cover the damn hole the connector cremated
Im starting to question myself why in the damn hell I sold the V
