05' E55 NO CRANK FAN ON HIGH ESP/ABS
Old 09-13-2015, 10:24 PM
e55izm's Avatar
040 w201 55 sold 040 w210 wagon 040 w211 55
The other day I went to go start my car, it wouldn't start. So I jump started it, car started up, drove to the gas station, turned the car off. it never started again. i was stranded at the gas station for hours trying to figure out what happened to it, after I couldn't figure out what was the matter with it i had to push it home. Everything in the car works except it just won't crank. lights on the dash are ESP MALFUNCTION, ABS MALFUNCTION, RED BATTERY LIGHT IS ON. (PUT A BRAND-NEW BATTERY IN AFTER I GOT IT HOME). WHEN I PUT THE KEY IN THE IGNITION IS SAYS REMOVE KEY. WHEN I TRY TO START IT THERES NO CRANK AND THE FAN JUST COMES ON HIGH. BUT LIKE I SAID BEFORE EVERY SINGLE THING IS WORKING EXCEPT IT JUST WONT START.
Old 09-22-2015, 05:51 PM
hank55's Avatar
e55 amg, gmc acadia, wrx, integra
This just happened to me today. Any answers
Old 09-22-2015, 08:44 PM
menace2sobriety's Avatar
2004 E55 AMG
I spoke to a guy who had these/similar no crank symptoms about 3-4 weeks ago (without the error messages though)
Issue was found to be his starter
Replaced starter and all was well, running mint again
He could turn the key and no click nothing from the starter, yet everything else would work, he removed the fuel line and fuel would prime etc etc, it just happened out of the blue
He had no codes in STAR
Not saying it is the same thing here but may be something to go on
Old 09-22-2015, 08:50 PM
hank55's Avatar
I was thinking the same thing. Thank god I have a warranty. I was afraid I bricked my ecu or something. But I did drive it around after reflash in so I don't think I bricked it. Lol. I guess I will find out in a couple days
Old 09-30-2015, 09:30 AM
e55izm's Avatar
menace thanks for taking the time to post. hank was ur fan running on high? keep me posted. list of things I've done. checked the f70 fuse under passenger foot well. I'm getting power there. front sam unit relay L was swapped and still nothing. swapped out bcm still nothing. alternator is getting power. checked every fuse still nothing. used a maxiDas scanner bcm came up with 2 faults k75 relay and dead aux battery. replaced both and still nothing. k75 relay is in front sam with yellow strip. haven't been able to get under the car yet to check for power to the starter. everything that i read about no crank and fan on blast says its a dead ecu. by way of the ecu cooling fan dying and killing the ecu along with it? makes no sense to me that the ecu would die because of a bs cooling fan shorting out. any input on this out there? will be checking the fuel pump today but I'm assuming thats a long shot because i should still have a crank. also might replace brake light switch another long shot? I've owned this car for years and it has never failed me until now.
Old 09-30-2015, 11:02 AM
hank55's Avatar
Per the dealer. I have a dead ecu.
Old 09-30-2015, 11:20 AM
e55izm's Avatar
did they say how it died?
Old 09-30-2015, 11:29 AM
hank55's Avatar
Negative. All they said was that it was a bad ecu and they had to order the part from germany.
Old 12-15-2015, 11:49 AM
e55izm's Avatar
Solved. Burnt ECU. Cloned it and back to normal. ECU clone $350. If ever needed pm.
Old 12-15-2015, 06:45 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Happened to me after downloading tune. If the car won't crank and you have an esp malfunction then it's the ecu. Hopefully other will find this thread in future. I didn't find it when I searched 3 weeks ago
Old 01-10-2019, 07:39 PM
E63007's Avatar
07' E63
Since I have replaced my Airmatic Compressor and relay, I seem to be having issues with Airmatic "retaining" the "Startup Settings" I have programmed in "Suspension Airmatic Setting for ride height. I have to manually login to STAR/Xentry to Suspension/Actuations/Automaticall Suspension Adjustment IIRC? Once there it shows how low in mm the FR/FL & Rear is and then I press F3 and the Airmatic inflates and I'm good to go, that is, until the next day when upon startup the car DOESN'T calibrate by itself as it should???
I'm not sure if this pertains to my issue, but when using Xentry/Chassis/Suspension/Voltages-it shows N51 (Airmatic w/ADS) Terminal 30 as having 14v with car running, however below it shows Terminal 87 as having no Voltage? I'm wondering if this might be the reason for Airmatic Control Module NOT Remembering its Settings?
Bear in mind I've spent the last year rebuilding this "new to me" awesome ride and haven't even put so much as 100 miles on the car yet as I've had a hell of a time trying to get the car aligned properly. Without being able to retain Height Settings coupled with my car still pulling right, even after rebuilding thee entire front suspension that pulled right beforehand, it's been pretty frustrating!!! I don't really want to ruin these new tires due to the pull to the right, but first things first, I do need to figure out this ride height issue. The Compressor fills up the shocks on demand in Xentry, but doesn't self correct as it should???
Old 08-03-2022, 04:57 AM
MUSTANGRIDAH's Avatar
04 E55/04 SL55/R35 GTR
Were you able to communicate with ECU at the time? Pull codes etc? Also what is the contact for ECU clone?
Old 10-29-2022, 09:11 PM
jobett's Avatar
2006 c230
I need one of these
I need a ecu clone lmk what I need to do mobile number is 8654374570
Quick Reply: 05' E55 NO CRANK FAN ON HIGH ESP/ABS
