how many hours for this work?
E55, Mazda CX9
Ive got more work needed on the 55, my local mechanic didnt seem very scientific when quoted for the hours it would take.
Can you give me an idea of hours work for the following jobs,
Job 1
Replace X2 New Air Shocks
Replace Control Arms
Replace Upper Ball Joints
Replace steering knuckle
Replace inner and outer front wheel bearings
Job 2
Split SC cooling and wire SC pump to constant
Job 3
Pull fan shroud, replace all four belt pulley bearings,
Pull SC pulley, torque and gap correctly, reinstall
Job 4
Split trans cooling, add uprated trans cooler, flush and replace fluid
Job 5
Replace all spark plugs
I can do some of this myself but I'm very tight on time, work is hectic, will pick and choose depending on the hours.
Job 1
Job 2
Job 3
Job 4
Job 5
I'd definitely do Job #2 and Job #3 at the same time since you're in there.
Not sure how long it takes to open remove the radiator shroud, but I was able to do the jobs in about 2 hours without removing the shroud.
I drove the car up onto ramps, then removed the belly pan, and removed the two engine mount bolts from below. Then with a floor jack, I carefully lifted the engine about an INCH just enough to allow an impact socket over the SC pulley bolt. Then remove SC belt. Then strap the pulley so it doesn't spin, and remove in a few seconds.
Then remove all of the other pulleys, replace bearings, and reverse installation.
E55, Mazda CX9
Thanks, the work would be done by a garage that works on Euro cars not only Benz and no only AMG, they have STAR, see a few AMG's come through.
I'll share what i was quoted,
Fit New Front Air Shocks X2
Fit Steering Knuckle X1
Fit Mid Ball Joint X2
Fit Upper Ball Joint X2
Fit Control Arms X2
Fit Front Inner and Outer Wheel Bearings X4
Quoted 8 Hours
Trans Fluid Change / Cooler Flush
Fit New Trans Cooler
Quoted 2 Hours
Replace Spark Plugs
Quotes 2 Hours
Fit Control Arms X2
Quoted 8 Hours
Quoted 2 Hours
Replace Spark Plugs
Quotes 2 Hours
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I've seen m113 plugs on a r129 done in 8min. E55's can be done in 15-20min for any experienced mb tech. Torquing Is the most time consuming step. Job typically pays 2-3 hours depending on the shop.
Growing up around domestics, plugs on e55's are a walk in the park. It's, a air cleaner, 8 torx bolts and 16 boots. Not a big deal
The 129 is insanely easy. The 199 however...takes days.
