Black Smoke - 2ND Gear Pull
Old 09-23-2015, 04:08 PM
2000UZJ's Avatar
E55
Getting on the highway this morning.
Here is the status of the car.
Fuel: 22 miles Range
Engine Temp: ~almost fully warmed up
Mods: Listed in Signature
Oil: Fresh
Plugs, wires, etc: Fresh
Maintenance has been done religiously.
Situation: I get on it today on the on ramp and a huge plume of black smoke comes out the back right when I get into the boost (3-4K). I cannot get the smoke to come back (I haven't really tried though). It was a simple 2ND gear pull, probably 75% throttle. I usually short shift the car since I don't like taking it to the max all the time. It rarely sees redline. I shift around 6,000RPM
Thoughts?
Old 09-23-2015, 04:31 PM
blackbenzz's Avatar
haters crazy
How did it feel in terms of power? Black or blue smoke? I would do a compression test and leak down if you're really worried about it. Pull a plug and look at it if you're feeling lazy, if you see oil on it it's not a good sign. Could be just your car running rich but it wouldn't be a huge plume of smoke
Old 09-23-2015, 04:38 PM
2000UZJ's Avatar
E55
Idles fine, rev's fine (no smoke in free rev) and full power. It appeared to be black. I was looking at the rear view mirror as I laid into it (I look to check every now and then) and saw a plume and let off the gas. Went a few miles and kicked it back down and no smoke. I am de-catted so I expect a little more "action" out of the exhaust pipes
Old 09-23-2015, 05:10 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Black smoke is almost always because of unburnt fuel. Other cars I have had it was caused by a bad or failing injector or fuel pressure regulater. Not sure what is common cause on an e55.
Old 09-23-2015, 05:52 PM
2000UZJ's Avatar
E55
I will do another careful pull tonight and report back
Old 09-23-2015, 08:09 PM
2000UZJ's Avatar
E55
I'm about to leave. It's dark so I may just baby it until day light. I am thinking carbon build up (I have no idea how), oil blow by through the PCV, or the one step colder plugs and it's getting colder out (stock pullies). I got it tuned when it was 98*F and now it's in the 60's.
Old 09-26-2015, 11:19 AM
2000UZJ's Avatar
E55
Several code starts and no smoke. It's been cold and rainy the past two days and hasn't smoked and no loss of power. I had one hot start where the car stumbled right when it fired but idled fine. I cut it off and let it sit for a second and did another hot start with no stumble. It still feels 100% except for the fact that I can't really get past 50% throttle without the back tires breaking loose. No smoke or strange sounds under hard rev's in P or N.
I am booking a compression/leak down this week. If anybody has any other ideas let me know. It was a plume of smoke getting on the highway under heavy load in 2ND gear. Car did not stumble or sound strange when it happened. Just some smoke
Old 09-26-2015, 03:06 PM
chawkins2001's Avatar
2006 E55 AMG
What are you looking in the rear view mirror floor, put your foot through the floor board and hold on
I bet it was just some carbon build up coupled with unburnt fuel exiting the exhaust. Leak down will definitely put you at ease.
Quick Reply: Black Smoke - 2ND Gear Pull
