HELP!! E55 AMG sucking in oil through throttle body
Old 09-26-2015, 01:20 PM
Sk9106's Avatar
I own a 2006 E55 AMG parts list longtube headers e63 exhaust ftpheat exchanger and a crank p
I'm in need of some serious help my e55 is sucking in oil into the throttle body from the hoses that are attached to the airbox and the valve covers what could be causing this please if anyone has any insight I would greatly appreciate it! Thank you in advance
Old 09-26-2015, 02:47 PM
Sk9106's Avatar
Anybody?
SICAMG (09-09-2017)
Old 09-26-2015, 03:39 PM
s.i.f.i.'s Avatar
'03 Brabus E55 K8, '11 C300 4matic
First guess is a bad PCV valve. 2nd guess is blowby. At idle, remove oil fill cap and feel for pressure coming out. Pray you don't have any. Then go find the PCV valve and see if it's stuck open. That, for this car, is about my limit...
Old 09-26-2015, 05:08 PM
Rocman8's Avatar
E55
There is no PCV valve. Make sure you are not overfilled with oil.
Old 09-26-2015, 05:14 PM
s.i.f.i.'s Avatar
Ah so! back to hoping no blowby then...
Old 09-26-2015, 06:58 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Oil in the intake track in pretty common on these cars. If you are worried do a compression test.
Old 09-26-2015, 11:21 PM
E55Greasemonkey's Avatar
Received 1,483 Likes on 983 Posts
This place is a joke.
A small amount is normal.
Old 09-27-2015, 10:41 AM
Sk9106's Avatar
I'm going to be running a compression test and hope for the best. Now here's my question if the outcomes bad rings where would I be able to find a set of new pistons and rings for this car? Is such a thing available?
Old 09-27-2015, 12:32 PM
Rocman8's Avatar
E55
how much oil are we talking about? do you have pictures? did you confirm you oil is not overfilled?
Old 09-27-2015, 12:43 PM
Hulk's Avatar
A Merc
If it's bad might as well just get a uses block in good shape than replacing pistons and rings.
Btw how long have you had the car and did you do a compression test before you bought it?
Old 09-27-2015, 12:46 PM
Hulk's Avatar
A Merc
Double post
Old 09-27-2015, 03:38 PM
Sk9106's Avatar
the car is smoking when I start it up and oil is at 8.2 quarts it only has 60k on it as well and when I took the air box off oil was coming out of the y pipe
Old 09-27-2015, 03:42 PM
Sk9106's Avatar
it came outta nowhere as well I started the car up after not driving it for a week and knew something was not right when it sound like it was misfiring
Old 09-27-2015, 03:43 PM
Rocman8's Avatar
E55
Yeah that's not good. Are you reading 8.2 quarts in the cluster when the engine is off or on? And hot or cold?
Old 09-27-2015, 03:49 PM
Sk9106's Avatar
7.8-8.2 quarts when the engine is on and trust me im freaking out. I can understand if I was beating on the car and something happened but the car was running fine When I parked it and then I go to drive a week later start it up and it's misfiring and smoking quite a bit. If I have to replace the engine where would be a good place to get one or just a block itself would work I could just swap everything over then
Old 09-27-2015, 03:52 PM
Sk9106's Avatar
the cars also modded as well supercharger pulley crank pulley 82mm tb ftp heat exchanger cm Johnson intercooler pump super sprint headers and a tune
Old 09-27-2015, 03:53 PM
Rocman8's Avatar
E55
It still may be unrelated but you need to completely rule out the oil level first and do compression check before you get ahead of yourself. You don't check oil level with car on. You need to check it once it's warmed up and with the engine switched off after sitting for ten minutes.
Old 09-27-2015, 03:55 PM
Hulk's Avatar
A Merc
Did you buy the car modded?
Old 09-27-2015, 03:59 PM
Sk9106's Avatar
will do I'll keep you guys posted I hope it's something little I miss driving it lol with such low mileage on the car I shouldn't be having any issues
uzzle7 (10-10-2023)
Old 09-27-2015, 04:01 PM
Sk9106's Avatar
Yes from a really good friend that bought all the parts and had them professionally installed
Old 09-27-2015, 04:28 PM
Hulk's Avatar
A Merc
Mileage means nothing. I have seen cars with 50k miles and the motor had bad compression. Whether its friend or family , it is a purchase so do your home work. Compression test is a must. Many cars these days are being sold cheap and have issues. Hope it works out for you bro
Old 09-27-2015, 05:15 PM
Sk9106's Avatar
Yeah sh*t happens I guess at least I have my srt4 for a daily I can take my time fixing the E55.. cars paid for it would have stung a whole lot more if I had a loan on it
Old 09-28-2015, 06:37 PM
It sounds like you have too much oil in the engine. At idle the cluster shouldn't read more than 5 qts or so...if the sensor is correct. Drain the oil from both sumps, replace the filter (do this before draining the oil as it will let more oil run to the pan) Refill with 8.5 qts and see how it goes. It will take some time to burn off the excess oil in the breather system. Or, have someone competent (not jiffy lube) change the oil, be sure to ALWAYS use a factory filter.
Old 09-28-2015, 06:41 PM
Rocman8's Avatar
E55
+1
Old 10-01-2015, 06:21 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Have the oil level checked with a dipstick. As I recall it should measure between 16cm and 17cm. Hopefully it's just an overfill.
I installed an oil catch-can years ago and the TB remains bone-dry to this day. Prior to the installation, there was always a slight oil residue.
Quick Reply: HELP!! E55 AMG sucking in oil through throttle body
