Need help please!!! battery light and engine oil level lights coming on.
Old 10-01-2015, 09:34 AM
bnzuovr's Avatar
2004 W211 E55K, GL550
Hey guys was hoping some of you guys could maybe help me out. Been getting some error messages on the dash.
1st my battery light comes on and all convince functions are turned off. I checked the aux battery and main battery both seem to be charging correct with the volt meter large battery is charging at 14.0 volts and small battery is charging at 12.68(is this normal?) also aux battery is brand new as of yesterday but still have the error coming up on dash board. The light does not stay on all the time comes on when it feels like it. I'm thinking voltage regulator is going bad but when i test with multi-meter voltage is at 14 volts.
2nd issue,
Engine oil level visit work shop light comes on erratically when it feels as well some times on cold starts sometimes while im driving, not sure what this is but i was assuming it could be oil level sensor in the lower pan. But again not sure was hoping some one had same issues and could give me further info. Would greatly appreciate any and all help.
Old 10-01-2015, 10:37 AM
mkiv_tdi's Avatar
Jetta TDI [Daily] , Audi A8L [Sold], '12 STI [Sold], '06 E55 [Sold], '05 S500, '15 GLA250
I wouldn't spend too much time worrying about the oil level sensor and just change it out with your next oil change. Takes 2 minutes and it's 3 torx bolts.
Mine would show everything from "add a quart" to the RED "stop car immediately" oil message. All is good now.
****that's assuming your know you've got the proper amount of oil in the engine. lol. If you drain it and 3qts comes out, you should have probably listened to your sensor :p
Old 10-01-2015, 12:26 PM
bnzuovr's Avatar
well ive checked the monitor on the screen and it says "oil level is ok" and i also have a dealer dipstick and have checked the oil level and it shows its in range. So i should be alright. is the level sensor on the bottom side of the oil pan or in the oil pan?
Old 10-01-2015, 05:54 PM
bnzuovr's Avatar
Has anyone had experience with the voltage regulator working intermittently? Could that be the problem? Im out of ideas as ive looked the car over and cant find any tell tail sign of what it maybe.
Old 10-01-2015, 06:09 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Good luck on the oil level sensor. As of yesterday there were none in Germany and 2 weeks ago there were only 4 in the U.S.
Old 10-02-2015, 04:33 PM
Funk Season's Avatar
06 Mercedes-Benz CLS55 AMG
You are probably seeing 12.68 on the aux battery because it wasn't charging at the time. I don't think it gets constantly charged so that is normal
Old 10-02-2015, 08:07 PM
desired_speeds's Avatar
2007 SL55 AMG
pull up the voltage menu on the gauge cluster and drive around to see if it dips below 12v.
Old 10-02-2015, 08:48 PM
Rocman8's Avatar
E55
There are 14 available on amazon through VG European. OEM part.
Quick Reply: Need help please!!! battery light and engine oil level lights coming on.
