How many oz of freon needed for an ac recharge?
Is there an amount of oz's that are needed for a recharge or does it go by a certain reading on your climate control? I just added the killer chiller and just have this left to do
Stock is 2.4oz iirc
With KC start off with 2.2oz and drive around then test, then add if needed, then again add if needed, continue until you find the best without going over 2.6oz
Make sure you change your dryer when you do the evac and vacuum
That's around what I was thinking but wasn't sure couldn't seem to find the underhood sticker, yeap went with a new dryer as well, I guess I will give that a try thank you!
Cruising highway iat's were between 55-59 it was 79 outside worked great so far, will see tomorrow afternoon how it works, got to sort out a few kinked water lines also wrap the ac, trunk tank and lines anybody know the best stuff that would work? something from maybe home depot or DEI?
