Stock plugs and 180pulley/77 sc pulley
My plugs are fresh (5k) if I do a 77mm clutched do a need a step cooler? Most do it but I'm not sure weather it's worth doing if my plugs are good.
PLATINUM SPONSOR
Yes, good to go on fresh plus and you will love the power.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
