Voltage Regulator or Alternator???
Old 06-16-2016, 04:47 PM
justinp95's Avatar
E430
So I got the dreaded battery lights, no ac ect. Anyway, Its not the rear battery or the aux battery either. Rear tested ok and aux i replaced. Alternator test came back DIODE OPEN. Is it the alternator or the Voltage regulator????? And which regulator should I buy?
Old 06-16-2016, 05:06 PM
verminator's Avatar
2010 E63AMG
The voltage regulator's function is to convert the ac output from the alternator to a dc output through a diode rectifier (ac to dc). The dc voltage is what is used in the cars electrical system. The failure mode of the voltage regulator is a diode failure which decreases the power output capability of alternator. The other diodes in the rectifier try to make up for the loss of the diode and get over loaded/stressed and they fail, power quality also gets bad in the car, lots of ripple in the dc...Replace the regulator and you should be good...GL
Old 06-16-2016, 05:28 PM
justinp95's Avatar
E430
Are there different alternators on these cars? I found the PN for the bosch one, but is there an alternative?
Old 06-16-2016, 05:34 PM
justinp95's Avatar
E430
Also, FYI test showed " No load, 11.3 V" and " Loaded 11.5 V" if it matters. Seems pretty low.
Old 06-16-2016, 08:25 PM
verminator's Avatar
2010 E63AMG
So you regulator is shot. There is a great diy posted on the site....search it. There are also allot of posts that describe the smell of melted/overheated alternator insulation, then it is game over and time to replace the alternator. Sounds like you've caught it in time. Don't run it, get the regulator replaced. Look at the sticky for parts and i'm sure the regulator is on there...i can't quote the manufacturer of the alternator but Bosch is likely...regulator is cheap ...$30ish...the alternator is much more...GL
Old 06-17-2016, 02:45 AM
Jelanib's Avatar
2004 E55 AMG
DIY - https://mbworld.org/forums/w211-amg/...lternator.html
VR $33 at Autohaus - http://www.autohausaz.com/search/pn....76&brand=Bosch
Old 06-17-2016, 02:25 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Wow ... only $33 for VR on E55? Mine was $70 for E320CDI. I pulled my alternator out though because I tried to replace the whole thing with a re-manufactured one. But the re-man did not work at all. So I just ended up changing the VR ... I still was getting Battery low message but turns out the main battery has a low capacity .. as soon as I switched to 900 CCA battery, no more issues.
Here is my DIY .. it is actually very similar to the E55 in terms of layout ... I had to pull the radiator fan out.
https://mbworld.org/forums/diesel-fo...nator-diy.html
Old 06-20-2016, 10:40 AM
justinp95's Avatar
E430
Ya i never smelled any burning plastic. Got one for $43 shipped so hopefully its the issue!
Old 06-30-2016, 08:06 PM
justinp95's Avatar
E430
Replaced the regulator and that wasn't it. Replaced the alternator and now it's at 13.3 while it's on.... What should I check next besides the terminals ?
Old 07-01-2016, 08:59 AM
justinp95's Avatar
E430
Re tightened battery terminals and it initially went up to 13.7 then started dropping to 13.5.
Key on after this adjustment the battery was at 12.7.
Old 07-01-2016, 05:11 PM
turbo97se's Avatar
What makes you think things are still not fixed? 13.5 to 13.7 is still in normal operating range with car running. Mine is in this range. Unless you are getting Battery low Convenience features disabled message, this is fine.
Old 07-01-2016, 10:36 PM
Rocman8's Avatar
E55
Yes you are good to go. Alternator fixed it.
Old 07-14-2016, 08:57 PM
justinp95's Avatar
E430
Well today on the way home I got the battery light again! Alternator is not charging. It's sitting at about 11.9 running. What should I change now? I hear there is a relay of some sort?
Old 07-14-2016, 11:20 PM
Rocman8's Avatar
E55
What alternator did you get? Reman bosch? Aftermarket?
Old 07-15-2016, 07:30 AM
justinp95's Avatar
E430
It was a autozone reman.
Old 07-15-2016, 08:06 AM
Rocman8's Avatar
E55
Sounds like another bad alternator.
Old 07-15-2016, 09:16 AM
justinp95's Avatar
E430
As i thought, the Duralast brand is a Bosch Reman unit.
Old 07-15-2016, 09:26 AM
Rocman8's Avatar
E55
AutoZone has horrible reviews for their alternators. Some don't even work right out of the box. It bay be a bosch core but they definitely don't remanufacture it to high standards.
Old 07-15-2016, 10:57 AM
justinp95's Avatar
E430
Hmmm, When I looked at the forums I didn't see any bad reviews just a few recommendations. I hit it hard coming out of a gas station before this happened so maybe something just came loose. Ill ramp it tomorrow and swap the voltage regulator just in case.
Old 07-16-2016, 12:52 AM
turbo97se's Avatar
I had bad luck with a Duralast. Mine, I believe actually caused my radiator fan. Also Autozone only had lower power (150A vs 200A for CDI).
Old 08-02-2016, 04:06 PM
justinp95's Avatar
E430
Does the W211 have this fuse? X4/10? Im not sure i believe an alternator would just die after a week.
http://www.justanswer.com/mercedes/3...-charging.html
https://mbworld.org/forums/cl-class-...ator-help.html
Old 08-05-2016, 11:03 AM
ZeroE350Seven's Avatar
MB 2007 E350
Hi, you can request Autozone to bench-test yours at the store.
If the reman. Alternator you just bought was a bad one.
Old 08-05-2016, 11:18 AM
justinp95's Avatar
E430
Well, thats not really the issue. I already have the replacement ready to go in. The problem is the time and effort to get the damn thing out. I can see its not charging by looking at the voltage gauge. So its the alternator again or there is a fuse somewhere (like the one above) no one knows about.
Old 08-05-2016, 06:27 PM
Mr. CVE's Avatar
MY06 E55
Similar happened to me, met a friend driving the highway, thought I would show him some fun,
and bang the dash went red, and the car into shutdown.
Turned out it was the reg, replaced the reg and was on my way.
If there is no voltage coming out of the alt when running, check the input triggers. if they are there it is a bad alternator.
I tried to pull mine out, but was a pain, ended up doing the reg in the car.
Old 08-05-2016, 06:34 PM
justinp95's Avatar
E430
Can you explain this a bit more? Input triggers?
Quick Reply: Voltage Regulator or Alternator???
