Transmission unsure of what gear to select and over revving upon shifts P1614 & P0730
SPONSOR
2007 Mercedes E63 AMG
Hey guys just an FYI.
If any of you have issues of your transmission shifting funky and feeling like it's basically slipping and getting into the wrong gear check your transmission fluid level. I recently had codes for P1614 - Powertain and P0730 - Incorrect Gear Ratio. After much diagnosing I had my buddy check my fluid level which needs to be done on a lift with the engine running. Seems the transmission was 1-2 quarts low. After topping off and resetting codes all issues were solved and yet to return.
